Power Door Lock Problem PLEASE HELP!!!
Old Dec 9, 2008
bols151's Avatar
bols151 is an unknown quantity at this point
OK. there was an issue wit the alarm system. The 2 wires touched and the everything got messed up. When I use the alarm the lock for the passnager works fine. But the driver side lock wont go down anymore. Anyone have an idea how to fix it. I use the switch inside it looks like it want to go down but it looks stuck. HELP!!!! using key outside is fine.
Old Dec 10, 2008
manster972's Avatar
manster972 is an unknown quantity at this point
Re: Power Door Lock Problem PLEASE HELP!!!
Sounds like the actuator on the lock assembly needs to be replaced, I had the same issue on the passenger side door. It wouldn't work from my remote or the switch inside, I could only lock & unlock the door manually. I replaced the actuator & everything been fine since.
roverben
Jan 21, 2019 05:16 PM
maaronia
May 14, 2015 10:46 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
