94 Civic coupe (D16Z6) Automatic transmission problems...
It's a little odd what it does, but anyways. It's like it just refuses to shift after the transmission gets around operating temperature (after about 20-25 minutes of driving), it gears down and sticks in 3rd, and then sometimes when it gets worse, it'll downshift to 2nd and won't go any higher. The engine revs continuously and does not shift. I've replaced the speed sensor (speedometer wasn't working, still isn't.) seeing if that'd help anything, but it didn't. Are Honda's just that picky as to what fluid you use in them (I've been using Castrol Import-Vehicle ATF, the fluid in it leaks a bit and I have to keep an eye on it). What could the problem here? Any help is appreciated.
Re: 94 Civic coupe (D16Z6) Automatic transmission problems...
i dont know about auto trans that much but i changed them out before in hondas. go to your local junk yard and buy a used auto trans and put it in and it should work fine. i swapped one in a 96 civic
Pr0n1s
Apr 30, 2015 03:08 PM
alexkharden
Apr 23, 2015 07:13 PM
