Coil vs. Ingiter
Old Nov 14, 2008
motofabio's Avatar
motofabio will become famous soon enough
Coil vs. Ingiter
Sorry for the newb subject matter here, but I lean towards bikes rather than cars. Anyway, the mechanic is telling me that the igniter is bad. But the coil was just replaced.
WTF is the igniter? Is it another name for the ignition coil?
2000 Civic EX
Thanks!
Old Nov 15, 2008
DsevenEm2's Avatar
This is Myspace
Re: Coil vs. Ingiter
Ok basically, your Ignition Coil builds up voltage created by your engine, while its running.
Your Igniter tells the Ignition Coil when to release that voltage, through the leads, onto the spark plug.
Just because you replaced the coil, doesn't mean that the igniter can't still be bad. You can test resistance on the igniter with an ohm meter, but you'd have to look in a service manual to find out how to do it correctly.
Old Nov 15, 2008
motofabio's Avatar
Makes sense. Thanks!
Old Nov 17, 2008
motofabio's Avatar
So will a bad igniter burn out the coil?
Old Nov 17, 2008
DsevenEm2's Avatar
This is Myspace
It won't "burn out" the coil, but it will cause it to not act right. They work in conjunction with each other. When one's not working right, the other will act funny, and vice versa.
Since you replaced the coil, I'd say replace the igniter.. but you might have to replace the whole assembly.. I can't remember but you have a distributor right? I'm pretty sure the Igniter is in the distributor as a small module, if not its in an external "ignition module" type deal.. I'm not too sure on your car though.
You need a service manual lol.
Old Dec 4, 2008
motofabio's Avatar
Follow up -- igniter replaced. Runs great again. Thanks!
runawaykinms
15
Mar 22, 2019 10:32 AM
jammer48
Oct 4, 2018 10:04 PM
h4ldol
Apr 24, 2017 08:16 PM
Cam Diaz
Sep 29, 2015 07:17 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
