1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
01 civic blowing fuse
Old Nov 13, 2008
ricksgp's Avatar
ricksgp is an unknown quantity at this point
Working on my son's 2001 civic. It died while driving and would not restart. Found a 15 amp fuse marked FI ECU blown. Replaced it and when I turned the ignition on it blew instantly. Did some online research and all I found seemed to indicate the fuel pump relay was bad. What I found online said it was blue relay behind the glove box. Replaced that and the fuse still blew. Even with relay out it blew. There was a brown relay beside the blue. Replaced it and it still blew. Removed it and, bingo, it did not blow. Replaced brown relay and disconnected wire to fuel pump. It blew. So the only way to keep fuse from blowing is to remove the brown 4 blade relay. What does this go to?
Would appreciate any advice anyone can offer, I'm stumped.
Thanks for your time, Rick
More Info: Looking in a Chilton's it appears this is the PGM-FI main relay No. 1. What does it feed?
Thanks, Rick
Old Nov 24, 2008
fathan16's Avatar
fathan16 is an unknown quantity at this point
Re: 01 civic blowing fuse
sounds like something my pathfinder was doin, it had a short in the wiring, i dont know how much electrical you'll have look at but maybe a wire just got too hot
roverben
Jan 21, 2019 05:16 PM
alexkharden
Apr 23, 2015 07:13 PM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
Sarsura507
Feb 5, 2008 09:54 AM
