Koni/GC Banging
Old Nov 3, 2008
EnvyX's Avatar
EnvyX will become famous soon enough
Koni/GC Banging
New suspension is banging over bumps. Nothing is loose, just bangs. Pretty sure the topmount is in right as well. Lowered probably 2.x" Not 100% sure but the Lip is 5 inches from the ground
Old Nov 3, 2008
robbclark1's Avatar
Retired suspension supermod.
Re: Koni/GC Banging
Are you bottoming out?
Old Nov 3, 2008
d0ughbOy81's Avatar
d0ughbOy81 is an unknown quantity at this point
Re: Koni/GC Banging
im having the same prb in my girls em2 shes droped on EIBACH PRO KIT and kyb agx shocks it only happends when ur on bumpy roads or speed bumps. it sounds like the top mounts are loose. iv checked everything and nuthing is loose
Old Nov 3, 2008
EnvyX's Avatar
Re: Koni/GC Banging
well to be honest I don't know what bottoming out would sound like. But I did find out that my compliance bushings Are shot.
Old Nov 4, 2008
robbclark1's Avatar
Re: Koni/GC Banging
Then you may be bottoming out because the control arm is pushing up more than it should.
Bottoming out = loud bang when you hit a bump and you feel the car vibrate because basically you just hit the top of the shock against the car frame.
Any grease coming from the shocks? Did you cut the perches off the struts?
Old Nov 4, 2008
EnvyX's Avatar
Re: Koni/GC Banging
perches are cut off, no grease coming out. and the car doesnt vibrate when the noise happens. In fact it just absorbs the bump like normal but with an obnoxious noise. And sometimes it even happens over the smallest bumps.
Old Nov 5, 2008
robbclark1's Avatar
Re: Koni/GC Banging
Replace LCA bushings with ES poly ones. Check all bolts and maybe raise the car up a bit.
Old Nov 5, 2008
d0ughbOy81's Avatar
Re: Koni/GC Banging
were do u get the es poly bushings
Old Nov 6, 2008
robbclark1's Avatar
Re: Koni/GC Banging
www.google.com haha
Old Nov 6, 2008
greeen01civic4d's Avatar
Re: Koni/GC Banging
energysuspensionparts.com
Old Nov 6, 2008
civic4dizoor's Avatar
civic4dizoor is on a distinguished road
Re: Koni/GC Banging
wouldnt it be the strut bearings makin noise when goin over small bumps
Old Nov 14, 2008
Zzyzx's Avatar
Autocross Junky
Re: Koni/GC Banging
when mine made noises.... the 1st time it was the upper main nut on the strut that was loose. the 2nd time the lower main bolt came loose (Alen Head Bolt).
the top nut is easily checked, but have you checked the lower one?
Old Nov 17, 2008
EnvyX's Avatar
Re: Koni/GC Banging
no...havent taken the strut out yet...
Old Nov 17, 2008
Zzyzx's Avatar
Autocross Junky
Re: Koni/GC Banging
You dont need to remove the strut, just get under the car and check to see if the bolt (Allen Head) going through the bottom of the strut is still there... there have been several instances where people complained about konis banging with them finding that the bottom bolt had worked its way loose.
you're looking for this bolt..
Old Nov 20, 2008
EnvyX's Avatar
Re: Koni/GC Banging
alright ill take a look
repped
Old Nov 20, 2008
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
Re: Koni/GC Banging
+1 for Zzyzx
i had the same thing happen to be but after a while, that just started to spin around freely but my shock itself gave out so...
Old Dec 23, 2008
Maple50175's Avatar
Maple50175 is an unknown quantity at this point
Re: Koni/GC Banging
yeah every suspention I have had BANGS at the smallest bumps Im on d2's now and the ride sucks.
I hate civics for this reason. Seriously. Talk about loosing control when I hit a bump on a turn
Old Dec 23, 2008
Zzyzx's Avatar
Autocross Junky
Re: Koni/GC Banging
my 1st question would be how low is the car riding....
edspyhill09
Jun 12, 2016 02:45 PM
