Koni/GC Banging
Koni/GC Banging
New suspension is banging over bumps. Nothing is loose, just bangs. Pretty sure the topmount is in right as well. Lowered probably 2.x" Not 100% sure but the Lip is 5 inches from the ground
Re: Koni/GC Banging
im having the same prb in my girls em2 shes droped on EIBACH PRO KIT and kyb agx shocks it only happends when ur on bumpy roads or speed bumps. it sounds like the top mounts are loose. iv checked everything and nuthing is loose
Re: Koni/GC Banging
Then you may be bottoming out because the control arm is pushing up more than it should.
Bottoming out = loud bang when you hit a bump and you feel the car vibrate because basically you just hit the top of the shock against the car frame.
Any grease coming from the shocks? Did you cut the perches off the struts?
Re: Koni/GC Banging
perches are cut off, no grease coming out. and the car doesnt vibrate when the noise happens. In fact it just absorbs the bump like normal but with an obnoxious noise. And sometimes it even happens over the smallest bumps.
Re: Koni/GC Banging
Replace LCA bushings with ES poly ones. Check all bolts and maybe raise the car up a bit.
Autocross Junky
Re: Koni/GC Banging
when mine made noises.... the 1st time it was the upper main nut on the strut that was loose. the 2nd time the lower main bolt came loose (Alen Head Bolt).
the top nut is easily checked, but have you checked the lower one?
Autocross Junky
Re: Koni/GC Banging
You dont need to remove the strut, just get under the car and check to see if the bolt (Allen Head) going through the bottom of the strut is still there... there have been several instances where people complained about konis banging with them finding that the bottom bolt had worked its way loose.
you're looking for this bolt..
Re: Koni/GC Banging
yeah every suspention I have had BANGS at the smallest bumps Im on d2's now and the ride sucks.
I hate civics for this reason. Seriously. Talk about loosing control when I hit a bump on a turn
Autocross Junky
edspyhill09
Jun 12, 2016 02:45 PM
