d17 FIDANZA FLYWHEEL... and EX ECU
brand new fidanza flywheel $150 shipped... i bought it from a fidanza retailer but never got a chance to put it on.. its still in the box.. BRAND NEW!!!... NOW $140 SHIPPED!!
i also have an ex ecu... i believe it fits any model 01-05 and yes it works perfect.. correct me if i am wrong if it doesnt fit all the models... part number
37820-PLR-L02.... 150$ shipped
pm me for any questions
Re: d17 FIDANZA FLYWHEEL... and EX ECU
^is there a DIY on here or soemthing? or is there a manual or something with instructions?
does the haynes manual show you?
Fidanza Flywheels reduce the moment of inertia characteristics on an engine, thereby increasing useable power to the wheels. Using a Fidanza aluminum flywheel not only offers dramatic increases in useable power, but can also potentially extend engine life by reducing the stress on the crankshaft and main bearings.
By the way putting in a flywheel is just like doing a clutch except you have to do 1 more step. The flywheel is located behind the clutch and to take it off you just have to remove 6 bolts. The clutch and pressure plate together grip the flywheel to get the car moving. So just consider it a clutch job.
^you should change the price in the firsst post as well, cuz most ppl will look at that first and wont know you changed the price to 140
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
260000milesgoal
Sep 25, 2015 07:41 PM
beanhead
Sep 24, 2015 12:04 PM
191161, 37820, 37820plrl02, d17, ecu, fidanza, flywheel, instruction, l02, model, plr, replacement, specific
