Is there a diff when it comes to ball joints?
Old Oct 5, 2008
vtec_concept's Avatar
vtec_concept is an unknown quantity at this point
I have a ball joint problem,
the problem is that I did a complete shock, spring, and ball joint install on a car in which I had bought used....
I bought a 2002 Civic EX w/ Sohc VTEC Motor.
the rear shocks and springs was installed without a hitch...
the passenger side shock, spring, ball joint, again installed without a hitch...
yet the driver side is where the problem lies...
the shocks and springs installed without a problem sort of, but the ball joint was a pain to install even with a press and hammering the crap out of it, still it would neat seat properly to the point where I cant put the cotter pin...
what we had found is this:
I had to enlarge the two bottom bolt holes for the shocks on the driver side, so thus that must mean the previous owner had changed the spindle to an 04+ Civic or could it be another Civic that requires that bolt holes to be enlarged on a 02 Civic strut
one problem is trying to figure what ball joint application do you I use? Seeing the 02 Civic problem that i had tried to use seems to be not the right one
or is there a difference with ball joints from a 03+ Civic, 02 Civic+ Si (EP3 application) ???
so any suggestions folks?
Old Oct 5, 2008
robbclark1's Avatar
Retired suspension supermod.
Re: Is there a diff when it comes to ball joints?
No, they all use the same ball joints.
Get a ball joint puller and use it in reverse. You can rent them from advance autoparts.
Old Oct 6, 2008
skoot's Avatar
skoot is an unknown quantity at this point
does anyone have a diagram of where the ball joint is? I know that sounds stupid...sorry.
UltraHDGames
Jun 8, 2016 05:16 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
Joecrowe
Sep 24, 2015 09:12 AM
bashea
Sep 15, 2015 04:59 AM
