Wierd Stuttering problem at 2k rpm
Old Aug 31, 2008
DX5spd's Avatar
DX5spd is an unknown quantity at this point
OK i searched for some time looking for some kind of help but nothing is coming close. I have a CEL for a p1509= Idle Air Control Circuit Failure. Is this just as simple as a new IAC. The big problem which i think is being caused by this is when I try to hold 2k rmp my engine does this stuttering that almost sound similar to hitting the rev limiter but at 2k rpm. It does it at any speed in any gear at any temp. Its affecting my driving alot. When in fifth gear going fourty (which is a very common speed for me on most roads i drive) the rpm's are at 2k which is when the bucking and stuttering start. I have tried a new(used) IAC valve but no luck. Another symptom i have noticed is at any time before 2k rpm the throttle is smooth but after 2k rpm the throttle gets touchy and i can't really hold any rpm after 2k. Higher rpm's don't stutter too bad. If i get the chance to upload a vid of it i will cause its difficult to explain. Any help is appreciated.
Old Aug 31, 2008
Re: Wierd Stuttering problem at 2k rpm
get a whole new throttle body assembly off ebay for maybe $50, make sure its for your type of trans auto or manual. put that in, with new gaskets, and do the idle learn.
Old Sep 7, 2008
micco's Avatar
micco is an unknown quantity at this point
my s13 does the same thing at 2500rpm if the maf is plugged or faulty.
Check all the wires to the sensors, also remove the intake pipe and carefully check for any cracks.
Old Oct 23, 2008
DX5spd's Avatar
ok got a new throttle body, installed it, did the idle learn and it still does the same thing. i even put a different IAC valve on. I dont know what to do now how and what would I check for vac leaks and what else could i check. Im starting to think its the ECU any.
Old Oct 23, 2008
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Yeah but shouldn't he check wire that plugs into IAC valve? It could be defective.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
NROD315
Sep 23, 2015 03:46 PM
charmon4815
General
Sep 22, 2015 08:00 AM
Bruce2
Sep 21, 2015 08:01 PM
Bricoleur
Sep 9, 2015 12:23 PM
