reccomend me some new brakes
Old Jul 29, 2008
kcari's Avatar
lately i've been noticing a squeeking noise whenever I have a passenger and noise when i gently apply the brakes at low speeds. Plus whenever I have my E brake on the rear rotors will still spin (someone pointed this out to me when i got my fenders rolled). Could the squeek be rust on the rotors or discs?
My car is at 56,000 miles. Should I just go with OEM pads or are there any better aftermarket alternatives that won't cost too much.
Old Jul 29, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: reccomend me some new brakes
you have a rear disc conversion? i got EBC ultimax pad for relatively cheap and they work great. stops faster than OEM but with a little more brake dust. i brake hard and they still look like they have a lot of meat on them after 15k of hard braking.
having rust is normal so no it wouldnt be the rust i dont think. the rust gets rubbed off when the brakes are used.
Old Jul 30, 2008
kcari's Avatar
no i dont have a conversion. its all original OEM parts and i do not believe its been changed before. Any ideas on why it squeeks when someone seats in the passenger seat and completely silent when there isnt anyone there. I hear this increasing squeeking noise off and on during drive (not during braking).
Old Jul 30, 2008
hypnotic20's Avatar
hypnotic20 is an unknown quantity at this point
Maybe you are over loading your car? Do you have a system in the back?
Old Jul 30, 2008
D5cIvIc's Avatar
kyle, you should get the rotora BBK. that's the next set of brakes i'm getting. It's over a 1K though. Spend the cash to play man. DO IT!
Old Jul 30, 2008
TemjinX2's Avatar
if you don't go to the track or go canyon running, i say just get oem pads. The hawk pads grip better but give off more noise and brake dust. Just search for gearbox's review of hawk and oem pads.
Old Jul 30, 2008
kcari's Avatar
sorry, to clarify- the squeeking is in the front passenger seat. It has been getting louder. On and off squeeking while driving. And my sub weighs 15 pounds or less. Could the brake pads be causing the squeeking?
Old Jul 30, 2008
TemjinX2's Avatar
its probably just the brake indicator telling you to replace your brakes.
Old Jul 30, 2008
^^ wurd. the brake pads are designed to squeak when they need to be replaced. listen to them ^__^
Old Jul 30, 2008
kcari's Avatar
okay will do - thanks for that
btw, is 56,000 miles generally okay?
I do sort of ride the brakes at times - i can't drive.
btw how much do u think it'll cost to replace 4 OEM pads
and my ebrake button sometimes gets stuck when I want to push on it to let go.
Old Jul 30, 2008
IMO i think 56k miles is longer than usual.
Old Jul 30, 2008
ronaldo9's Avatar
Hawk Pads or EBC greenstuff is what I recommend. Should not cost alot. And you most likely DON'T need to change the shoes in the back just the front.
Old Jul 30, 2008
johnbt23's Avatar
if u haven't changed your brakes going on 56,000 miles, and your on your brakes a lot, than yeah, i think u might be hearing the squeking from the brake indicator....
Old Jul 30, 2008
Oem pads and rotors
Old Jul 30, 2008
kcari's Avatar
does the brake pad indicator squeek when driving and when braking?
anyone know why my e brake button gets stuck sometimes and I have to smack it with my palm in order for it to release?
Old Jul 30, 2008
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
^Probably because you have it pulled up too hard. The higher you pull it up, the harder it is going to be to push that button. From my experience.
Old Jul 30, 2008
johnbt23's Avatar
yes, it squeeks when driving and esp. during braking
Old Jul 30, 2008
is it bad that when i use the ebrake when stopped, sometimes the rear brakes lock up and i have to step the gas to make it break loose again? lol hmm
Old Jul 30, 2008
sl33pyriceboi's Avatar
hawks HP plus pads are bout the best pads you can get for our civic....
its made with ferro carbon.....which is alot better than most...
dezod had some ferro carbon ones too, but they are on backorder...(and theres a good reason too)
Old Jul 30, 2008
filipinop1405's Avatar
filipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of lightfilipinop1405 is a glorious beacon of light
gotta look into this....
Bricoleur
Sep 9, 2015 06:48 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
thaler4cuse
Sep 7, 2015 08:25 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
