Rubber Piece Between Springs Torn
Old Jul 17, 2008
qijian's Avatar
so im lowered on s techs with blues and i just noticed not too long ago my front driver side rubber boot with the bump stop are torn. At first it was just the lower half of the rubber boot that was broken off/tore off/ ripped apart/ im not sure but it fell apart. Now when i checked up on it, the upper half is also torn and i think this time it took the bump stops with it. Kinda looked cracked or something. So my question is, should i replace the rubber boot or just leave it? because if i were to replace it i would have to take everything apart, but if its not really useful then i would just leave it. Thanks for any help!
Old Jul 17, 2008
Tragedy's Avatar
skate or die
Re: Rubber Boot Torn
You have to take the axle off to replace the boot. Is your axle in good condition? Might want to replace the whole thing. If it is ok, just replace the boot. The grease inside will deteriorate and collect dirt/dust/water from the open cracks, which will wear the part out faster.
Old Jul 17, 2008
sicma99ot's Avatar
just a man with a civic
sicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of lightsicma99ot is a glorious beacon of light
i have the same thing. while putting together my suspension, the strut fell and tore the boot and almost severed the brake line if i hadnt caught it. got a broken finger out of the deal.
Old Jul 17, 2008
qijian's Avatar
oh no no, sorry if i wasnt clear by i dont know the name of the piece of rubber inside the strut. Its like after you put the springs onto the strut, then theres the OEM rubber piece thats your reuse to reassemble the strut. I forgot the name but its that piece thats cracked off with the bump stops
Old Jul 17, 2008
rjngo's Avatar
rjngo will become famous soon enoughrjngo will become famous soon enough
i think he's talking about the bump stop on the shock and not the CV boot
Old Jul 17, 2008
qijian's Avatar
yea yea! sorry if i mislead anyone -__-
Old Jul 17, 2008
sicma99ot's Avatar
Re: Rubber Piece Between Springs Torn
oh i get what your saying now.
im not sure i thatd be bad.
Old Jul 17, 2008
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enoughEggRollBandit05 will become famous soon enough
you should replace it, the dust boot/bump stop costs less than $15 and it keeps the strut from bottoming out
Old Jul 17, 2008
kcari's Avatar
http://www.hondaautomotiveparts.com/...SHOCK+ABSORBER
is what ur talking about part number 16?
my dust cover (13) was hitting my coil so i trimmed it.
Old Jul 17, 2008
^^^thats for the rear hes talking about the front #8
Old Jul 17, 2008
kcari's Avatar
do you have to cut those in half when you install coilovers? I think I'm running without them and a half trimmed dust cover.
Old Jul 17, 2008
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
It should be replaced. Basically what it does is prevent dirt and grime from getting into the inner seals of the strut, which over time will cause it to leak and eventually blow.
Old Jul 17, 2008
qijian's Avatar
ohh ok. i should replace it then. BTW, does anyone know how compressed the tein s techs are if i were to take apart the strut? last thing i want it to do is go shooting out.
Old Jul 17, 2008
DDragon7's Avatar
I dont know but, your going to need a compressor to put it back together again anyways.
Old Jul 18, 2008
joe6680's Avatar
Yeah definitely use a spring compressor, the safety factor outweighs the cost factor.
Old Jul 18, 2008
speedricerx's Avatar
speedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of light
when i put on the stechs, i needed very little force to put it on, i didn't need a compressor but i guess safety first...
ricer_em2
May 11, 2016 08:09 PM
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Jrosa
Sep 14, 2015 08:24 PM
