Question about removing turbo pipes from turbo...
Old Jul 3, 2008
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
I'm slowly returning my car to stock in preparation to sell. I'm ready to install the stock resonator/air box, but don't yet have the stock exhaust manifold/oil pan. What I want to know is, can I remove only the intake pipes from the turbo to reinstall my stock air intake? (pipes highlighted in red) I'm referring only to the air filter pipe leading into the turbo, and the 3 pipes leading to the throttle body. This would give me the room necessary to install the stock intake. I can't think of any possible damage that would be done by having the turbine simply blow air out into the atmosphere, unless it contains exhaust gases, but I may be overlooking something. Are the exhaust gases contained strictly to the downpipe? I also know to put a simple filter covering over the intake hole so no rocks or anything get into the turbine and damage it. Advice/comments anyone?
Old Jul 3, 2008
andyman97's Avatar
Turbo Guru
Re: Question about removing turbo pipes from turbo...
I wouldn't do it for any extended period. You risk overspooling the turbo with no resistance against it....
Is that an sfp manifold?
Old Jul 4, 2008
Mex's Avatar
Mex
thanks for the reply... it's a stafford fabrications kit (one of the few who actually got theirs)
what is meant by overspooling? would this do damage to the bearings? also for a while now I've been running the turbo without the wastegate actuator rod attached so I won't build up any boost. is that anything different?
Old Jul 5, 2008
andyman97's Avatar
Turbo Guru
I've read about it, never seen it happen. Basically, the theory is, the more rpm and load the engine sees, the harder the turbo works. If there's no resistance against it, it just freespins. So yeah, if it's dumping and creating no boost, I would say it's about the same thing.
Old Jul 5, 2008
Rufus's Avatar
I'll buy your chargepiping....
GolNat
Suspension DIY
May 12, 2022 06:49 AM
CarStuff
Dec 6, 2020 12:52 PM
Supramk3
Jun 11, 2015 11:13 AM
cukaracha
Jun 8, 2015 05:41 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
