FS: Ingalls "Stiffy" Engine Damper EM2 & ES1
Ingalls new "Stiffy" torque damper is a elastomer shock that mount via 7 gauge steel brackets between the engine and the chassis, reducing or eliminating power robbing movement improving off-the line acceleration for your vehicle. The "Stiffy" has hardened spherical rod ends, aerospace grade fasteners, 6061-T6 Aluminum body and an adjustment range of 6.75" to 7.2".
- Greatly improved off-the line acceleration.
- Reduced wheel hop.
- Improved vehicle stability.
- Reduced shock loads on driveline components.
- Smoother shifting.
- Reduced wear on exhaust system joints.
- Less vibration transmission to the driver compared to polyurethane dampers.
$110 shipped in the US
Re: FS: Ingalls "Stiffy" Engine Damper EM2 & ES1
^ depends on the thickness of the strutbar's mounting bracket- you need to have enough threads to put the nut on. If ya do, it works.
No. There are bids but I can certainly cancel them for a civicforums member.
When I bought it it was missing bolts. They're all there now. The pic looks like one nut and washer but they're stacked. I had it on just like normal.
