AP2 Steering Wheel Q's
Old Jun 2, 2008
spudz904's Avatar
spudz904 is just really nicespudz904 is just really nicespudz904 is just really nicespudz904 is just really nice
Alright, i recently purchased an ap2 steering wheel and i am planning on installing it next weekend but im nervous about messing with an airbag. Ive read the other threads regarding the issue but im open to any advice, particularly from someone whose done the install. If i feel confident enough, i might write up a proper DIY.
I made sure to buy an ap2 wheel because of the dual stage airbag but when i check the back of the airbag i only see one yellow connector and i was under the impression there should be one yellow and one red wiring, for each of the two stages. I certainly hope i did not get an ap2 wheel with a ap1 airbag.
Old Jun 2, 2008
Unevolved's Avatar
Rough, Tough, Real Stuff.
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
Re: AP2 Steering Wheel Q's
Pictures, maybe?
How many contacts are there in the connector? And where'd you get the wheel?
Old Jun 2, 2008
Rufus's Avatar
I can help jooooooooo.......
I'm not certain that ALL AP2's were dual stage (it was a 2004 or 2005 change). The amount of plugs isn't the issue as there can be dual stage in a single plug. What matters is that there is a red set and a yellow set of wires (this will match yours).
I have an 03 wheel with an 05 bag right now. The install is too simple. It literally just unbolts. The only think that takes time, honestly, is the cruise control as it takes a little soldering and paying attention to wires. Otherwise I rate it a 3 on the difficulty scale.
Old Jun 2, 2008
spudz904's Avatar
Old Jun 2, 2008
spudz904's Avatar
Pictures, maybe?
__________________
I bought the wheel for $250 off of another forum, i can't quite remember which forum now, i think it might have been hondaswap or hondamarketplace. I posted pictures of the connector ^.
Its kinda a relief that someone else is currently doing this. If your bag is dual stage, does it resemble mine? I believe the wheel is off an 05.
Old Jun 2, 2008
Rufus's Avatar
Thats a single stage. Pick which one you want to work on your own car and put a 2ohm resistor on the other to keep the light from coming on. Personally, I'd sell it and get the right bag.
I looked at a 2005 on ebay and the wheel/bag are correct. That means they must not have made the change to dual stage until 2006 (kinda behind the times you think?)
Here is a 2006 off eBay and it has the same airbag as mine. You can see they look different.
Old Jun 2, 2008
spudz904's Avatar
Not to be a pain in the *** but could you possibly take a picture of your airbag, back and front? I think i might have found another wheel with the correct bag but i don't feel like going through this process again and i just want to make sure. And thanks for your help +1
Old Jun 2, 2008
Rufus's Avatar
It looks just like the one I posted above. The back looks like yours but it also has a yellow set of wires in addition to those red ones.
Old Jun 2, 2008
spudz904's Avatar
So basically your airbag looks like this from behind, with the exception of it being an s2000 airbag?
Took this from another thread
Thanks for all the help btw
Old Jun 2, 2008
Rufus's Avatar
Ding ding
Old Jun 3, 2008
skipbarber's Avatar
you can also swap out the detonators. people used to do that with the jdm ep3's.. since jdm was single stage and usdm was dual. you could remove the detonator and swap them. of course, you do this at your own risk and getting a dual stage bag that will actually plug in and work is always better.
Old Jun 16, 2008
spudz904's Avatar
Alright, i managed to get my hands on a brand new 2008 s2000 steering wheel with a dual stage airbag but ive encountered a problem. The connector from the civic for the airbag does not match the connector from the s2000 airbag. There both four pins but they do not match up. I know absolutely nothing about anything electronic so im at a standstill.
I was thinking i could remove the connector from the ap2 airbag and replace it with the connector from the civic airbag so the bag will match up with the car but im not sure that will work. Any ideas? I WILL NOT change the detonators, that just doesn't sound safe but ^ thanks for the idea. Every incomplete diy i read involves a 2ohm resistor and cutting wires, i do not see why any of this would be necessary.
Old Jun 16, 2008
spudz904's Avatar
Connector from civic to airbag
Connector from civic airbag
Connector from s2000 airbag (the wires for the s2000 airbag are smaller than the wires for the civic
Old Jun 17, 2008
Rufus's Avatar
Ya it's not plug and play man, you have to cut and solder them.
Old Jun 17, 2008
knight_321's Avatar
knight_321 has a spectacular aura aboutknight_321 has a spectacular aura about
the DC5 or EP3 is just straight bolt on yeah?
none if this air bag issue yeah??
Old Jun 17, 2008
Rufus's Avatar
It's not a scary thing, just clip and solder.
Old Jun 18, 2008
spudz904's Avatar
Finished the job so im currently writing up a DIY
thanks rufus
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
GotSiR
Jun 23, 2016 04:06 PM
alaga
25
Aug 13, 2015 04:42 PM
kaashifv
Interior
Jul 27, 2015 05:28 PM
qlitten
Jul 21, 2015 03:12 PM
