1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
heater stays on when cars off/keys out
Old Apr 23, 2008
civic93's Avatar
civic93 is an unknown quantity at this point
i have a '93 honda civic dx
when i shut everything off and take the keys out... i can still go and slide my heater/ac switch and the fan will turn on and blow!!!! now my battery doesnt work! what should i do??? and where is it located? please help!!!
Old Apr 23, 2008
CraigW's Avatar
Re: heater stays on when cars off/keys out
Put the key back in and move the ignition switch slightly back an forth and on and off, with the fan on to see if at any point the fan shuts off.
Old Apr 24, 2008
civic93's Avatar
isn't there a fuse for the heater? i dont have the manuel. or is there a plug i can unplug for the heater? cuz my battery is dead and i can't see if the heater will come on again... but when i jump it i just want the heater off i guess.... i think thats the only solution.
Old Apr 24, 2008
pheaton's Avatar
A descendant of 2k1civic.com
That's a fancy problem. Switch must be jacked up. Pull the fuse buddy. See if you can find a new switch.
Old Apr 24, 2008
CraigW's Avatar
There should be a relay for the blower as well. It would be easy to remove.
Old Apr 24, 2008
if you turn the switch to off position, does it turn off? that would be the easy fix is remember to turn it off.
Old Apr 25, 2008
civic93's Avatar
yea i did shut it off the whole time... but it still drained the battery.
Old Apr 25, 2008
CraigW's Avatar
You may have other items draining the battery then in addition to the heater blower.
Anything else work when it should not?? Or other strange happenings.
You may need to pull the - battery cable for now.
Old Apr 25, 2008
maybe something happened to the resistor...
mikemc422
Aug 9, 2018 05:41 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
Blaster30
Apr 22, 2015 12:21 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
