reconditioned my headlights this morning...
Old Apr 20, 2008
FALKEN's Avatar
Civicforums Junkie
STEP: 1
tape off around the headlight so you dont sand your precious paint job
STEP: 2
wetsand the headlight
(use 800 grit if the lens is really bad)
(use 1000 grit if lens has normal issues)
STEP: 3
wipe headlight dry
STEP: 4
(use 1000 grit if your first sanding was 800 grit, then move on to 2000 grit)
(use 2000 grit if your first sanding was 1000 grit)
STEP: 5
wipe headlight dry
STEP: 6
buff headlight using plastic polish/cleaner
(i used a drill attachment to speed the process)
FINAL RESULTS:
Old Apr 20, 2008
7thGenerasianCivic's Avatar
Re: reconditioned my headlights this morning...
sweeeeeet
Old Apr 20, 2008
slowwhitecivic's Avatar
slowwhitecivic will become famous soon enough
the headlight in the first pic didnt look like it needed to be recondition but damn urs came out real nice and smooth...last time i try mine came out shitty and u can still see some scratches lol
Old Apr 20, 2008
hvc's Avatar
hvc
hvc is an unknown quantity at this point
looks good man, and yeah, the headlight in the first picture doesn't even look that bad?
I think I'm going to have to do this sometime this week.
Old Apr 20, 2008
Eyger's Avatar
A long winded 7th genr
Eyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond reputeEyger has a reputation beyond repute
Another way you can do this same thing to your headlights, I've done it before on a different car, you can sand everything like you did, then just spray a clear coat over the whole thing, it comes out crystal clear.
Slowwitecivic, you might see scratches because you didn't use a fine enough grain, or you didn't sand enough. those would be my guesses.
Old Apr 20, 2008
damian02civic's Avatar
damian02civic has a spectacular aura aboutdamian02civic has a spectacular aura aboutdamian02civic has a spectacular aura about
Don't sand or buff too hard or you have the chance of warping the lens which in turn would make the light come out the lens the wrong way.. or create 'grooves' in the lens.
Old Apr 20, 2008
hvc's Avatar
hvc
should you sand more with the higher grit, rather then more with the lower grit?
Old Apr 20, 2008
FALKEN's Avatar
Civicforums Junkie
Originally Posted by slowwhitecivic
the headlight in the first pic didnt look like it needed to be reconditioned
true, but im very picky and after seeing some of the fine scratches starting to appear, it was time...also, the passenger side was yellowing due to the way the sun hits it when i park at work.
last time mine came out shitty and u can still see some scratches
what grit levels were you using? you may need to go lower and then work your way up to 2000 or higher.
Old Apr 20, 2008
FALKEN's Avatar
Civicforums Junkie
The more you sand with the lower grits, the more "layers" come off. It may be necessary to sand longer with the lower grits if your lens is deeply pitted. Just make sure that you sand the whole lens evenly and work your way through the higher grits. The lens should be very smooth right before you start to polish.
Old Apr 20, 2008
make sure you seal it to protect what you did using a clear plastic sealer.
Old Apr 20, 2008
hXc drummer23's Avatar
hXc drummer23 will become famous soon enough
That is pretty similar to what I did, but I started with 1500 then moved to 2000. I also used Menzerna intensive polish via rotary on a megs burgundy pad, menzerna final polish via porter cable on a megs yellow pad, then plastic x via porter cable on a LC ccs white pad. It came out perfect. The only reason I went that in depth is because I detail cars as my job.
Old Apr 20, 2008
miami_em2's Avatar
miami_em2 will become famous soon enough
I just wet sanded mine and then cleared them....it looks so nice. But nice job falken.
Old Apr 20, 2008
i think im gona have try this again lol..im gona try to move up to 2000 grits
Old Apr 20, 2008
DsevenEm2's Avatar
This is Myspace
x2 or you can wait about a month and watch it go back to how it looked before.
Old Apr 20, 2008
sniperscout's Avatar
You VTEC...I-VTEC
sniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of lightsniperscout is a glorious beacon of light
where can you pick up plastic sealer
Old Apr 20, 2008
wolfgang clear plastic sealer. i use it on my lights every month or so. it beads water and protects from sun. very good for $40 the big bottle is worth it. i still have mine for over two years its still not empty. hmm cargeek used to sell but i cant figure out what the site url is
Old Apr 20, 2008
You VTEC...I-VTEC
thx i will do some searchin'
are you thinking of autogeek.net?
they have almost all of the wolfgangs products in bulk except for the sealant...go figure
Old Apr 21, 2008
yeah autogeek is where i bought mine a while back.
Old Apr 21, 2008
You VTEC...I-VTEC
so i did this and they did not turn out very good
what buffer/polisher thingy did you use?
I used the mothers red foam ball thing
Old Apr 21, 2008
use turtle wax rubbing compound before doing the final polish like scratchx or plastx.
Old Apr 21, 2008
ragingSPAM's Avatar
I just burnt my tongue
I used to do a lot of auto body work and the easiest thing we used and the cheapest was the mothers clearcoat polish...the ultra fine stuff...its like $10 a bottle but it works the best in my opinion
Old Apr 22, 2008
drunkenmagnum's Avatar
Looks good, now do my windshield
Old May 9, 2008
You VTEC...I-VTEC
I have officially failed at this and am about to throw my headlights away. I followed the steps and i can not get them clear again.
Old May 9, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
^^ what did you do wrong? i just did it and it came out fine! .. you probably didnt let enough water under the headlight while you were sanding. i used a sponge to squeeze on top of the area i was sanding [while sanding] to have water constantly fall under the sandpaper so it never gets dry. so sponge in one hand and sandpaper in the other for laymans terms. the most important thing is the final grade of sanding. i probably sanded with 2000 grit for 10 minutes on each headlight just to make sure everything was smoothened out then used the plastix and it came out very nice. the outside of the headlight is flawless now but the inside is kinna messed up for some reason. just redo the final grade sandpaper sniper and make sure there is always water under the sandpaper!
Old May 9, 2008
is it smooth? you need rubbing compound to smoothen the plastic and then you can go ahead with the plast-x to polish it up to clear. dont worry they cant be ruined and you have tons of plastic left to mess with lol. if you are lazy get an orbital polisher for the last two things to put on. it will shine up dont worry.
Old May 9, 2008
You VTEC...I-VTEC
i sanded with 2000 for a long time and i know to keep it very wet. it seems to be extremely smooth before i polish...i am using polishing compound and then plastx.
it pisses me off cause i am normally good with this sort of stuff.
i am starting off with 600 then 800 then 1000 then 1500 then 2000
Old May 9, 2008
shoulda stuck with 1000-2000. 600 is way to hard unless your sanding off eyelid paste :X
Old May 9, 2008
i actually used 400 to start off with so it should be fine. as long as you sanded all the grades of sandpaper very well it wouldnt be a problem.
Old May 10, 2008
You VTEC...I-VTEC
maybe that is my problem... i should go longer with say 800 and 1000
Old May 11, 2008
CiViCPrAnInG2k1's Avatar
is it just me or is the finish product looks kinda filmy and unclear?
