LS B18 and b18c5 head
is it possible to put a b18c5 head on an b18b block? wud that combo be good or is it the b16 head on the b18b block the better choice?
Re: LS B18 and b18c5 head
yes its possible. It would require you to upgrade your internals. just search for ls vtec. Your probably better off just buying a gsr engine and swapping that.
oh you can just buy a gsr motor for $2k.
http://cgi.ebay.com/ebaymotors/JDM-H...spagenameZWDVW
the only thing going for the b18b is that the bore is slightly larger so you get a little more torque. you can do all that work on a b18b and probably just make the same power as a stock gsr with i/h/e
honda-tech is better for your question.
just do the research and decide on your own.
Here's a link to this one guys ls vtec
http://www.honda-tech.com/zerothread?id=2180817
ls vtec is not a reliable motor. its a great motor but has alot of problems.
but if you do decide to do it here is the kit.
http://shopping.lightningmotorsports...cat=161&page=1
IMO i would rather a b16 or gsr. because a LOT of less hassle. but its up to you.
http://www.honda-tech.com/zerothread/1676914
That link will explain it all. Take some time and really read it. After that read it again. IMHO ls/vtecs and b20/vtecs have a bad rep. Build them right and they'll treat you right.
7thgensurvivor
Jul 27, 2015 08:23 PM
Kyles24
Jul 12, 2015 09:15 PM
