Found Part # for 01 civic fuel filter....16010-S5A-932
Old Jan 25, 2008
jackoncruzpr's Avatar
jackoncruzpr is an unknown quantity at this point
Hi guys,
Still here trying to troubleshoot this Civic. I want to replace the fuel filter itself. Correct me if Im wrong but doesnt the d17A1 have a fuel strainer at the bottom and a fuel filter built into the top of the pump?
The one at the top of the pump is the one I want to replace since its the main filter.
I went to my local honda dealer and thought I ordered it.....when I opened the box they gave me the canister that is on the outside of the tank.
I need the part # for the one built into the pump itself.......is that sold separately or is that something that can only be bought with a new fuel pump assembly?
Thanks
Old Jan 25, 2008
Re: Part # for 01 D17A1 fuel filter...........
Is this it? Part # should be 16010-S5A-932. Some people here have changed it before.
Old Jan 25, 2008
speedfoos's Avatar
I'm pretty sure you can only buy the whole pump assembly and it comes with it. When I pulled my pump for the swap to my Walbro 255, I don't ever remember seeing a fuel filter on top of it or anywhere near it, aside from the strainer at the bottom.
Old Jan 25, 2008
Here it is. Does this look like it to anyone that has changed it before?
http://cgi.ebay.com.sg/Honda-Civic-I...ayphotohosting
Old Jan 25, 2008
speedfoos's Avatar
That's the whole pump carriage assembly. I didn't know there was a filter in it though. The only filter I saw (and I had to disassemble it to install the new pump) was the strainer on the bottom. If there's one in there, Honda does a good job of hiding it.
Old Jan 25, 2008
Yep. There is a filter in there. Im gonna go ahead and order that. Change it out after I do my valve adjustments and I still have the same problem.
Old Jan 25, 2008
Here are soem more pics I found of it......
http://www.yiparts.com/data/Engine/H...38f796be9.html
Old Jan 30, 2008
streetglower's Avatar
Re: Found Part # for 01 civic fuel filter....16010-S5A-932
yes you can replace the filter seperately, the filter is actually what the pump connects too. did mine a few years ago.
slikor
Nov 1, 2001 04:13 PM
