does this mean i need new engine mounts?
Old Jan 24, 2008
my car is vibrating again 65-75mph range or higher, i have brand new tires, blanced and aligned, it didnt help. now when i let go of the gas, the vibration completely stops. does this mean the engine mounts are messed up? and how easy is this to change?
Old Jan 24, 2008
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Re: does this mean i need new engine mounts?
ESMM for the win!!!
Old Jan 24, 2008
isnt that alot more vibration? lol
Old Jan 25, 2008
02BLKCIVIC's Avatar
i love mine but after the break in, its not that bad.
I heard of people installing the ESMM on just the front mount too. ill bet that wont be too bad.
but the ESMM will for sure help your motor mounts last WAY longer
Also before i installed my ESMM i went through two sets of all the mounts. before 80k
Old Jan 31, 2008
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
Have you looked at your mounts ??
Old Feb 1, 2008
speedfoos's Avatar
You can always poly-fill the mounts. More work, but less money.
Old Feb 2, 2008
jackscivic's Avatar
jackscivic will become famous soon enough
check your mounts first. dont forget to check the rear as well. i kno its hard to see the rear but they do go out fairly often. if you say you just had your tires ballanced then next i would check your struts. check them from leaks.
if your still havent found nething then its time to go back to the wheels/tires. a wheel can be perfectly balanced but the tire can have poor tire wear, read zero no a balance machine but still vibrate. on most tire balance machines it would say its balanced bc there is no actual road contact. get the wheels and tires a dynamic road force balance. id be willing to bet that they would fail.
also run your hand over the tire and see if it feels smooth or very bump and ridgy. and rotate the front tires to the rear and see if the vibration changes to the floor or if its felt in the steering wheel. if you can, also post the alignment sheet specs. if i can see the before specs i can tell you the condition of the tires.
Old Feb 2, 2008
greeen01civic4d's Avatar
its not tires, but it could be ur flywheel or pressureplate (assuming ur manual) it could have hot spots on it, or it could be motor mounts, and as far as the inserts go, its only more vibration at idle with loads on(ie. a/c) i have esmm and stiffy, and donthave much vibration, but i did before i had my flywheel resurfaced, i know u cant just check that, but its a thought to keep in mind
Old Feb 3, 2008
Rufus's Avatar
Check the two giant bolts that hold your stuts on too.
Old Feb 3, 2008
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
sometimes its suspension related... we had some people come to the shop with the same problem and come to find out.. it was the A-arm bushings
Old Feb 3, 2008
thanks guys. ive been out of town til now so i can deal with it again. the tires were brand new, now have 2k miles on them, and it is not the tires. the vibration comes and goes. i drove lots of freeways and sometimes between 65-75 there would be zero vibration. then out of the blue it would start to vibrate. weird eh? then it would go away again. idk. either its a bad mount and the engine is sometimes finding a good spot, or its suspension related like someone said. but the shocks are barely 6 months old and not leaking. so something else. i have an auto. i guess i will check the mounts first (easiest), then look at the suspension. also i had new rotors and pads put on, now it is making a scraping sound whenever i turn and stop. thats prolly not good either but its a separate problem.
Old Feb 3, 2008
man, ihave this same problem, and my front lca bushings are shot, im wondering if it has something to do with them, and with ur brakes, the grinding is normal, its just the pads and rotors getting worn in, wouldnt worry about that
Old Feb 3, 2008
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
does your wheel shake as well? check your tie rod ends if so.
Old Feb 3, 2008
yeah its the wheel that shakes, not the car. sorry if that wasnt clear. it feels exactly like a wheel balance issue, but i know its not that, because its not a constant vibration. i too thought about the tie rods, but idk. this whole thing started when i switched rims from stock SI alloy to konig hurry. same size, few pounds lighter, but maybe its the rims? im just guessing. its such a weird thing. my second guess was the tires need to wear according to all the new suspension stuff like drop, alignment, whatever but that makes no sense and obviously it didnt happen. hmm... the shop said they can check the mounts for $15 fee. im just gonna bring it in cause to me they look normal. maybe its cracked and i cant see it. blah
Old Feb 3, 2008
easy fixer.. try swapping the fronts with the rears.. (rims) like how u rotate tires and drive again... its a free and easy to trouble shoot thing.. dont need to spend money on it
Old Feb 3, 2008
you know its funny, cause when i had the old tires on and i swapped them front to back, the vibration got worse. so i switched it back the way it was and it got less. i always thought it was the tires fault because they had uneven wear. but i guess not. . what would make rims do that tho? they werent bent when they went on.
Old Feb 3, 2008
well.. put it this way.. i used to have the same problem way back when...
used to always go to this same guy to balnce my rims... everytime i go back he said it was fine... decide to bring it to another shop.. they checked it and said it was off balance.. so now i dont go to that shop to balance my rims anymore..
point is that some places try to and some places know what they are doing
Old Feb 3, 2008
you might also try to have them road force balanced, its what i use, and i swear by it now, we have one at my shop, and its a life saver, it can also tell u if u have a bent rim or bad tire that is the cause of the problem...
Old Feb 3, 2008
okay i can ask if there is anything else they can try. i remember they used gram weights one time. maybe the car is just really sensitive. and yea, im at the shop now that knows how to balance. same happened to me where i had to find another place that could do it right.
Old Feb 3, 2008
my guess is u got a bad tire, im telling u have it road force balanced, it will tell u if u have a bad tire, i swear by it man, its fantastic
Old Feb 4, 2008
i will look for a place to do that thanks.
Old Feb 7, 2008
looks like i need new front bushings. they are dead almost $300 labor and parts.
Old Feb 7, 2008
was it the a-arm bushings like i said?
Old Feb 7, 2008
yeah i think so. they showed me with the wheel taken off and it was all torn up. they just had another civic in with the same problem with around 80k miles.
Old Feb 19, 2008
jackscivic's Avatar
thats why i went to Energy suspension. i got tired of replacing the factory bushings over and over. i do it myself so it doesnt cost much but its still a pain in my ***. i swear by poly now!
Old Feb 19, 2008
02BLKCIVIC's Avatar
what is the entire production line for the 7th gen from Energy???
got it.
http://www.energysuspension.com/pages/hon1.html
they do make lower front and rear control arm bushings.
COOL!
Old Feb 19, 2008
sweet now who sells em? id rather go that route and not worry about replacing it later again
Old Feb 20, 2008
02BLKCIVIC's Avatar
let me know if you find em...
Old Feb 21, 2008
TuRtLE714's Avatar
TuRtLE714 will become famous soon enoughTuRtLE714 will become famous soon enough
me too i need to replace mine asap
Old Feb 22, 2008
why what happens? other than the vibrating, will axle fall off or something lol
