1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Unleaded/Premium gasoline
Old Jan 14, 2008
horton's Avatar
horton is an unknown quantity at this point
Hi its me again, asking a very noob question.
My Dad used Unleaded gasoline for our Civic Esi '95.
But Since the price of unleaded and premium gasoline almost the same now, I would like to try using premium.
My tank is currently 50% filled up with unleaded.
Can I feed premium as early as now?no harmful effect on mixing up?
pls help.thanks
Old Jan 14, 2008
greeen01civic4d's Avatar
Re: Unleaded/Premium gasoline
no, actually, mid-grade is nothing more than a mixture of premium and regular, so its really no big deal, its a common myth that u cannot mix gasolines, just the same with synthetic and conventional oil, changing and mixing is no big deal
Old Jan 14, 2008
popee's Avatar
popee will become famous soon enough
jus remember you cant jus switch back and forth on the unleaded and premuim gas.. your car will run like **** if you switch back to unleaded once you start using premium gas,, i did that in my previous car i own .... didnt run the same soo i had to use premium gas until my car broke down..
Old Jan 30, 2008
civicninitwo's Avatar
civicninitwo will become famous soon enoughcivicninitwo will become famous soon enough
It is imerative that you use premium if you have a VTEC motor. For non VTEC I wouldn't use anything but midgrade. Mixing will not hurt. But once you've run the good stuff,don't switch back to regular.
Hope this helps.
jttegx
Apr 11, 2005 12:05 PM
LubeControl.com
Mar 23, 2005 09:45 AM
LubeControl.com
Mar 18, 2005 09:53 PM
gearbox
Sep 8, 2004 08:57 PM
pnoyster2k1cvic
Feb 24, 2004 01:58 PM
