valve cover gasket help???
Old Jan 4, 2008
schainm's Avatar
schainm is an unknown quantity at this point
hi folks,
newbie here. i've got an '89 civic hatchback si. i did an oil change recently and noticed a very small amount of oil at the driver side front of the the valve cover and some oil along the leading edge of the cover as well. i'm planning on replacing the gasket, tube seals and grommets but can't find any torque specs for the valve cover nuts. i've even called a local honda service dept. and they just said to tighten the nuts until the grommets are compressed.
anyone have the exact torque specs for this repair? i don't want to overtighten by mistake.
thanks!
Old Jan 4, 2008
reddawnman's Avatar
reddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to allreddawnman is a name known to all
Re: valve cover gasket help???
Originally Posted by schainm
hi folks,
thanks!
For the 7th gen, the specs are 7.2 lbf, but I don't even go that far sometimes - use a small *** ratchet and just get them to where it feels just a tad tighter than hand tight. You shouldn't be leaning on them or else you'll bust a bolt.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Fudman
Suspension
Feb 1, 2020 04:13 PM
Mercilus
Jun 7, 2015 10:00 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
