1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
d17a2 d16 transmission
Old Dec 31, 2007
snyder2k8's Avatar
snyder2k8 is on a distinguished road
im doing a swap on a 95 civic 4dr the motor came out of my 02 civic so im
modifying the motor to fit in my eg civic.only 3 things need to be modified
Intake Manifold,Distributors,motor mount.the 92-2005 civic CLUTCH, 92-2000 FLYWHEEL will fit.
ID:	73394   Click image for larger version
ID:	73395   Click image for larger version
ID:	73396   Click image for larger version
ID:	73397   Click image for larger version
Old Dec 31, 2007
speedfoos's Avatar
Re: d17a2 d16 transmission
Wait a minute. You're saying the tranny from a D16 fits the D17?
Old Jan 1, 2008
snyder2k8's Avatar
yes it can and Intake Manifold little mod to it.
ID:	73399   Click image for larger version
ID:	73400   Click image for larger version
Old Jan 1, 2008
speedfoos's Avatar
The more pics you can show of this the better.
What exact transmission are you using? Will you be using the the D16 or the D17 axles? So you will use the existing linkage rod setup on the D16 then? Have you actually road tested the car to make sure there are no issues with the D17 engine and D16 trans?
This is really promising news. Because if it really works, that means we (D17 owners) have more tranny and gearing options and can also get a cheaper LSD than the Quaife. We would just have to convert to a D16-style shifter assembly.
Update when you can!
Old Jan 1, 2008
snyder2k8's Avatar
d17 on the 01-05 em2 civic are cable tranny there no hole in center console floor.
so the linkage rod won't work. To use it you would need to make a hole on the floor.
Old Jan 1, 2008
snyder2k8's Avatar
92-2000 civic Intake Manifold,transmission will fit on the motor.im using a 93 civic tranny,CLUTCH,FLYWHEEL on the motor
Old Jan 1, 2008
speedfoos's Avatar
Yeah, I've been up, down and sideways on the intake mani and decided to just bite the bullet and get a custom one done instead of modding the Y8. Which is why I'm selling my Y8 intake mani and bits right now.
I'm not too worried about having to cut holes in the floor of my to make the linkage rods fit. That's easy stuff if the tranny bolts up and works.
What axles are you using?
Old Jan 1, 2008
snyder2k8's Avatar
what car are you doing the swap on
Old Jan 1, 2008
Buds302's Avatar
Buds302 will become famous soon enough
he has a boosted em2..... he wants diff gears. and i can feel his pain. the EM2 gears are just too short for turbo. 80 mph in 5th is 4000 rpm....**** that
Old Jan 1, 2008
snyder2k8's Avatar
i dont know if a 92-2000 civic shift linkage will clear the subframe.i could of tried the tranny im my em2 but i change my subframe to a rsx to do a k-swap.
Old Jan 2, 2008
snyder2k8's Avatar
more pic
ID:	73405   Click image for larger version
ID:	73406   Click image for larger version
ID:	73407   Click image for larger version
Old Jan 2, 2008
briand17a2's Avatar
briand17a2 has a spectacular aura aboutbriand17a2 has a spectacular aura about
Very interested. This is outstanding info.
Old Jan 4, 2008
rick1574's Avatar
rick1574 will become famous soon enough
subscribed, i'm very interested in this.
Old Jan 5, 2008
speedfoos's Avatar
Huh, look at that. It does link up. So I imagine you're using D16 axles in it. I wonder if the D17 axles would work in it? Could you take a photo of the linkage assembly on the top of the trans and how it comes out so we can guesstimate subframe clearance?
I wonder if it's possible to retro our cable shift assembly on to it if there are subframe issues.....
Old Jan 6, 2008
briand17a2's Avatar
just wondering if any more information was available
Old Jan 11, 2008
snyder2k8's Avatar
soon
Old Jan 26, 2008
briand17a2's Avatar
for more info, if you've got any. Thanks for posting on this in the first place
Old Jan 26, 2008
lordhelmet's Avatar
Update!!!
Old Mar 9, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
any update on this sheeeit?
Old Mar 30, 2008
03civicdx_420's Avatar
03civicdx_420 will become famous soon enough
BUMP!! anything new???
Old Jun 4, 2008
emjay's Avatar
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
bumppppppppp
Old Oct 26, 2008
jee88's Avatar
jee88 is an unknown quantity at this point
well its been a while now, what ever happened with this sheeit? im guessing the plan failed? i dont even kno if this guy is on this site anymore but i think its worth a bump
Old Sep 4, 2018
Anarchist42's Avatar
Anarchist42 is an unknown quantity at this point
Look guys, I managed to bolt up the D16Y8 trans to the D17A2!!
... And thats as far as anyone taking this seriously gets. Cost and labor from here teeters into maniacal levels.
Motor Mount Update: the Motor Mounts and the Transmission Mount are fine. The trans mount is missing 1 bolt on the top of the transmission, but otherwise will work. D17A2 Motor Mounts work perfectly fine.
Shift Linkage Issue: Much bigger problem than just cutting a hole in the floor. We have a subframe and exhaust pipe interfering with the path to the middle of the chassis. Not sure how to approach that, without doing a full exhaust conversion at least, just to make room. That way you wont have to cut too much. But going from a cable shifting system to a shaft linkage is gonna take a LOT of work. It looks like there is a boltup spot for the rear shift bushing already on the underchassis, but unsure if it lines up right.
Flywheel/Starter/Clutch Issue. After researching in a couple spots, you will have to use the D16Y8 flywheel and Starter, the D17A2 setup doesnt line up right at all. Research needed before you use the D17A2 clutch assembly, but supposedly it works, there is not a clearance issue, but it does get a little tight. Using the hydraulic clutch, the D17A2 setup doesn't line up at all. You will have to retrofit the D16Y8 clutch actuating assembly (or whatever its called) to work. Did not get that far. Also dont know how the transaxles will work out either.
Lot of nay-saying, but other than that, I dont know what else to tell you all. I got into this build for the gear ratios and seemingly cheaper cost, I'm getting out of it due to the headache and the added cost. Doing all the labor myself - can't imagine what someone would charge for this kind of work.
UPDATE: This build attempt was performed on a 2001 Civic.
Last edited by Anarchist42; Sep 11, 2018 at 08:03 AM. Reason: Additional information
Old Sep 4, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
This is a great thread! You need some kind of award for longest time passed before an update. Good read! Wish I had more to say.
How old were you when you decided to try this anyhow?
Old Sep 4, 2018
GolNat's Avatar
Prelude Owner
Wow!! Thanks for the information!!!
I'd give you an award if I could lol.
Old Sep 5, 2018
Not my thread, but I got into this mess myself, trying to save someone else the trouble.
Old Sep 5, 2018
what car are you installing the assembly to?
good job!
Old Sep 11, 2018
I tried it on the 01 civic, and it was an ever living nightmare. Going back to SLW on my build.
Old Jun 6, 2019
EK Jay's Avatar
EK Jay is an unknown quantity at this point
I know this question is 11yrs late lol but does anyone know if the d16 trans internals fit the d17 trans?
Old Jun 6, 2019
I'm saying no. The countershaft and mainshaft assemblies between the D17 and D16 are different lengths, and diameters and positions. MAYBE you can mess with the gear ratios, but I wouldn't know without trying it. You could try using the 1st, 2nd, and 3rd gears from the original trans, and swap the 4th and 5th gearsets on the Mainshaft and Countershaft. Since they interconnect 1st-3rd on the Mainshaft, you will HAVE to keep those gears anyway. 4th and 5th swap along with the accompanying syncros, maybe, but you'd have to try it.
I want to say it won't work, or it's not worth the trouble. If you can mod it to work, and prove up a performance increase on a dyno, I'm sure we'd all love to know. But you're experimenting, either way.
