View Poll Results: D light on trans flashing,trans not working right on 01 civic can anyone help?
Trans ?
0%
Wire problem or trans
100.00%
Voters: 2. You may not vote on this poll
01 civic auto trans Drive light flashing
Old Dec 9, 2007
hanie's Avatar
hanie is an unknown quantity at this point
Question 01 civic auto trans Drive light flashing
Installed turbo, blew head gasket, changed gasket, now trans acting up, was working fine, before we changed head gasket. Honda dealer would not look at it because of mods, so took them off, code comes up as trans problem,changed shift cylinoids, did not help, when put in gear D flashes, can anyone tell me whats going on ?
Old Dec 9, 2007
greeen01civic4d's Avatar
Re: 01 civic auto trans Drive light flashing
there is a tsb based on this, it seems that there is excessive wear on the 2nd clutch, it calls for replacing the auto trans, sorry man
Old Dec 9, 2007
is the dtc ur coming up with p0730
Old Dec 9, 2007
it means your trans is dying
Old Dec 12, 2007
valenzuela's Avatar
valenzuela should not be trustedvalenzuela should not be trustedvalenzuela should not be trusted
a blinking D indicator could mean a few things
-torq.converter clutch solenoid valve code p1753
-A/T clutch pressure control solenoid valve A code P1768
-A/T clutch pressure control solenoid valve B code P1773
-Shift solenoid A code P0753
-shift solenoid b code P0758
-Trans. range switch (short to ground) code P1705
i have a Honda 01 - 03 civic service manual if you have any questions
Old Dec 13, 2007
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
I had that same problem before and I was scared that my transmission was gone. But it turned out to be a loose wire so don't automatically assume your transmission is dead. I'm sorry I don't have any more information than that because the Honda service fixed it.
Old May 31, 2009
ddaann's Avatar
ddaann is an unknown quantity at this point
hi guys, where is located Trans. range switch pls
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
civic_gt
Apr 19, 2015 08:15 AM
