1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Clock and Radio not saving.
Old Dec 1, 2007
Neutrilizer's Avatar
Neutrilizer is an unknown quantity at this point
Hey,
I have a 1992 Civic EX-V and i recently got a transmission replacement. Unfortunately when I got it back from the garage the clock isn't saving the time, so when I shut off the car and start it back up, it says its 1:00. Aswell, the radio stations aren't saving. It always starts back up at 87.7.
This is a really unusual problem because the rest of the car is running great. Anybody have any ideas as to what could be causing this?
Thanks,
~ Neut
Old Dec 1, 2007
D16Z6_owner's Avatar
D16Z6_owner is an unknown quantity at this point
Re: Clock and Radio not saving.
check the back-up fuse in the engine bay fuse box. mine did the same thing
Old Dec 1, 2007
TIPPMANN's Avatar
TIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond reputeTIPPMANN has a reputation beyond repute
^^^I agree, check all your fuses.
Remember you have two boxes, one under the dash and one in the engine bay.
Old Dec 3, 2007
I actually have 2 in the engine compartment... I checked them all but none of them seem to be burned out. Is there a specific Fuse that would be?
Old Dec 3, 2007
mooze's Avatar
mooze is an unknown quantity at this point
not the fuse. if the fuse the wouldnt turn on unless wired incorrectly.
Old Dec 3, 2007
Thats what I figured. Theres something not working properly when I shut off the car. It's almost like im disconnecting my battery and **** is reseting itself.
Could it be an ignition issue? Maybe something with my battery?
Old Dec 3, 2007
TIPPMANN's Avatar
The constant wire that keeps the settings in the radio is loosing power or not getting any at all. You are getting power from the remote.
Turn the key off and check for voltage out of the constant.
Old Dec 4, 2007
TIPPMANN's Avatar
This may help a little.
1992 Honda Civic Stereo Information
Constant 12V+ Blue/White
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Driver's Pillar
Front Speakers 5 1/4"
Doors:
Left Front (+) Blue/Green Left Front (-) Gray/Black
Right Front (+) Red/Green Right Front (-) Brown/Black
Rear Speakers 5 1/4"
Rear Deck:
Left Rear (+) Blue/Yellow Left Rear (-) Gray/White
Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Old Dec 28, 2007
oh and btw the fuse box closest to the firewall is considered the engine compartment fuse box and the one mounted to the left "wall" of the engine bay would be the ABS fuse box
Old Jan 27, 2008
I found the problem. Turns out theres a fuse in the engine compartment named "Back Up". Its a 7.5A and it was blown. Thats what saves the clock and Radio stations. When I was installing my new Pioneer stereo, it needs the constant to have power. So when it didnt work, I tackled the fuse box. So now it works. Thanks for the help
Old Jan 28, 2008
bingo
ricer_em2
May 11, 2016 08:09 PM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Mc7602
Sep 17, 2015 02:01 PM
jpat21
Sep 3, 2015 11:32 PM
