Clock and Radio not saving.
Hey,
I have a 1992 Civic EX-V and i recently got a transmission replacement. Unfortunately when I got it back from the garage the clock isn't saving the time, so when I shut off the car and start it back up, it says its 1:00. Aswell, the radio stations aren't saving. It always starts back up at 87.7.
This is a really unusual problem because the rest of the car is running great. Anybody have any ideas as to what could be causing this?
Thanks,
~ Neut
Thanks,
~ Neut
Re: Clock and Radio not saving.
Thats what I figured. Theres something not working properly when I shut off the car. It's almost like im disconnecting my battery and **** is reseting itself.
Could it be an ignition issue? Maybe something with my battery?
The constant wire that keeps the settings in the radio is loosing power or not getting any at all. You are getting power from the remote.
Turn the key off and check for voltage out of the constant.
This may help a little.
1992 Honda Civic Stereo Information
Constant 12V+ Blue/White
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Driver's Pillar
Front Speakers 5 1/4"
Doors:
Left Front (+) Blue/Green Left Front (-) Gray/Black
Right Front (+) Red/Green Right Front (-) Brown/Black
Rear Speakers 5 1/4"
Rear Deck:
Left Rear (+) Blue/Yellow Left Rear (-) Gray/White
Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Ground Black
Dimmer n/a
Doors:
Rear Deck:
I found the problem. Turns out theres a fuse in the engine compartment named "Back Up". Its a 7.5A and it was blown. Thats what saves the clock and Radio stations. When I was installing my new Pioneer stereo, it needs the constant to have power. So when it didnt work, I tackled the fuse box. So now it works. Thanks for the help
ricer_em2
May 11, 2016 08:09 PM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Mc7602
Sep 17, 2015 02:01 PM
jpat21
Sep 3, 2015 11:32 PM
