gas mileage way down???
Old Nov 28, 2007
civicken74's Avatar
civicken74 is an unknown quantity at this point
Hi I have a 2004 civic with 65,000 miles on it. I've always gotten pretty good gas mileage as I drive around 120 miles a day for work. Just noticed within the last week that my gas mileage has dropped in half. Just need some advice on where to start looking for the problem. Do I need any sort of tune up? Thanks in advance for any help.
Old Nov 28, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
Re: gas mileage way down???
air filter, tire pressure, o2 sensor. my guess is you have a bad o2 sensor.
Old Nov 28, 2007
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Take a look at the obvious....air filter & plugs really on that car. There is no ignition components, just plugs. Fuel filter is in the tank and I have never ever done a filter on our cars at my dealership. If you don't have a check engine light on then I would assume just the basics. If the check engine light is on go get it diagnosis'd
Old Nov 28, 2007
either 02 sensor going bad, plugs, air filter, clogged injectors (use lubecontrol.com products). or low air pressure in tires, bad alignment, blown shocks, etc.
Old Nov 28, 2007
RedHonda00's Avatar
RedHonda00 is an unknown quantity at this point
i have the same problem 2000 honda civic ex, 67,000 mi. suppose to get 32 mpg but when i filled up and did the math about 23 mpg. whats up with that? filter did need to be changed though. what is an 02 sensor??
Old Nov 28, 2007
ArjoonKumar's Avatar
ArjoonKumar will become famous soon enough
check to see if ur gas cap is on right
Old Nov 28, 2007
manahoonie's Avatar
RedHonda00-
o2 sensor is an oxygen/air sensor in the exhaust (intake too, right? not sure...tired and all) that measures the gases to help make the engine run more efficiently
Old Nov 28, 2007
civicken74's Avatar
What type of plugs you guys recommend?
SidCivic
Sep 12, 2015 05:28 PM
bsmiley
31
Sep 1, 2015 06:11 PM
mrwhos
Aug 11, 2015 02:03 AM
andyandyy
Aug 7, 2015 07:14 AM
shaejb15
Jul 27, 2015 03:48 PM
