clutch pedal....sqeaks
Old Oct 22, 2007
letsfightfelipe's Avatar
letsfightfelipe has a little shameless behaviour in the past
Everytime i push it it it sounds like a sqeaking noise but not a high pitch tone just a err ehh err i don't know what it is or if i would need to lubricate something.
Old Oct 22, 2007
EMTwannabe's Avatar
EMTwannabe is an unknown quantity at this point
Re: clutch pedal....sqeaks
Common problem for our cars. You need to get on the ground on your knees and look under the steering wheel. Remove the plastic covers so that you can see where the pedal linkage goes through the fire wall. Press the clutch pedal with your hand, you'll see where there is is a ball joint kinda looking thing. When pressed in, spray some white lithium grease on the opening with you other hand. You might need a flashlight to see. Takes less than 5 min.
Old Oct 22, 2007
lordhelmet's Avatar
Hit it with some lithium grease first. If that doesn't do it(it didn't for mine) then grab a wrench and adjust the pedal stop(the thingy with the switch). This will tighten things up and the rod that goes through the fire wall will stop binding. Look around the pedal and see if you kinda get at what I am saying. Its kind of a poor set of instructions.
Old Nov 6, 2007
xceed09.slvrstr's Avatar
xceed09.slvrstr has a little shameless behaviour in the past
if greasing up the pedals don't work might be your clutch release bearing. i had the exact same problem. thought was the pedal too but never got to try it. then when i went and replaced the clutch, pressure plate, and flywheel i changed the bearings too. the squeak is no more. just like it was never there. for me it was never the pedal.
Old Nov 6, 2007
AmbulanceMonkee's Avatar
try this.
https://www.civicforums.com/forums/7...pic-added.html
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
