Keys Locked Inside Help Asap
Old Oct 19, 2007
letsfightfelipe's Avatar
letsfightfelipe has a little shameless behaviour in the past
My keys are locked inside my vehicle because of the auto lock on my 2002 civic ex. is there a way i can get to them without a locksmith? and how do you disable that damn thing?
Old Oct 19, 2007
speedfoos's Avatar
Re: Keys Locked Inside Help Asap
Auto lock? My '03 doesn't seem to have that.
Anyway, do you have a slim-jim? That's the easiest way, not to mention safest - which is what the locksmith will use. Barring that....not really. Sorry man, you're either calling a locksmith (recommended) or breaking a window (not recommended).
Any of you shady members out there have some tricks?
Old Oct 19, 2007
LogicWavelength's Avatar
7th Gen Photographer
LogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of light
Dood... I thought the autolock only worked as a RE-lock. Like... if you don't open a door within 30 seconds it locks it again. So... umm... unless you got some sort of aftermarket thing then... umm... sorry to hear about your problems.
Old Oct 19, 2007
EMTwannabe's Avatar
EMTwannabe is an unknown quantity at this point
maybe it's aftermarket. At work (shop) we use wedges and coat hangers. Carefully put the wedge between the door and the frame starting from the top corner. You can get enough space between the door and the body to slip a coat hanger in and pop the power locks.
Old Oct 19, 2007
mishqua's Avatar
mishqua is an unknown quantity at this point
lol that sucks,
Get your self somthing like a couple of books if matches place them about 3inches before and after the plunger ( the lock you push down when you lock it ) then get a coat hanger bend it into a j use a pair of pliers cause u want the bend at the bottom small. Then place the coat hanger in between your two match books guide it down were the plunger is give it a slight turn and lift up gently. just keep working it around the lock in 5min you should be able to find the plunger and unlock your car.
I'm not shady lol locks just keep honest people honest.
o ya if you don't know how to use a slime jim and break the conector it will cost you more then calling the locksmith.
Old Oct 19, 2007
mishqua's Avatar
They will use an under the window tool they look like a big wire j. Civics are too easy to bust the connecting rod , I was a locksmith till recently got tired of people whining about the price for opening the car's and house's.
Old Oct 19, 2007
HighBoost's Avatar
HighBoost is an unknown quantity at this point
civic comes wit three keys.. two black one and one grey one..
Old Oct 19, 2007
popee's Avatar
popee will become famous soon enough
here try this.. i never done it my self but might help you http://www.youtube.com/watch?v=1AJD2UEmKfs - open the door with a tennis ball
http://www.youtube.com/watch?v=FqZv2kxlTBg&NR=1 - how to unlock a car using a hose
Old Oct 23, 2007
mishqua's Avatar
lol Thats a pretty darn funny video too bad it wont work,
Old Oct 23, 2007
i actually found such an easy way
Old Oct 23, 2007
greeen01civic4d's Avatar
mythbusters busted that one
Old Oct 23, 2007
if you take a coat hanger make it into a U shape with a lip hanging off at the end. you can slide it right under the window and pull up the lock too easy took me 2 minutes max
Old Oct 23, 2007
yep, works everytime
bluedoggy1
Jun 20, 2015 11:25 PM
cperez53
Apr 16, 2015 09:31 PM
Killagi
Apr 12, 2015 10:42 AM
Juancho007
Dec 16, 2001 01:02 PM
