Tire Size
Old Oct 2, 2007
Nitro Express's Avatar
Nitro Express is an unknown quantity at this point
Tire Size
Hi, I am new to this forum. I just bought a 2000 Civic EX (clean car, low miles, perfect condition). It has the stock 185 x 65 x 14 tires on it. I will be using this car as a daily driver but I want to make some suspension (strut tower brace & rear sway bar) and tire upgrades. Can I put 205 x 50 x 16 tires on this car (without any concern of rubbing under any normal condition). I realize that people have put much large tires on these (but at what cost). My inclination is to stick with the 195 x 55 x 15 size, but going to the 205's would look so much nicer. Does anyone have any first hand experience here? Thanks for the help.
Old Oct 2, 2007
sql_civic's Avatar
Re: Tire Size
I'm running American Racing 15" Aero wheels with Nitto NT-450 205/50s on a 97 Civic HB. It's the same generation as your car so it should work for you as well. I only get a little rubbing when turning the wheel all the way to the left or right. I'm riding on the stock suspension (not lowered IOW).
Be careful about adding sway bars unless you know for sure how it will effect the over/under steering on your car.
Good Luck.
Old Oct 3, 2007
Re: Tire Size
Thanks for the info. I will likely go with the 195/55/15; I really don't ever want any rubbing. As for the sway bar how will know unless I put it on. I will leave the front one stock. In the rear I was planning on using a 19mm bar.
Old Oct 7, 2007
sql_civic's Avatar
Re: Tire Size
Read all about it here. You don't want to find out you messed up your suspension by hitting a tree.
Old Oct 7, 2007
greeen01civic4d's Avatar
Re: Tire Size
r u planning on gettin rims?? cuz if not, ur stuck with 14's
Old Oct 8, 2007
mugenpower89's Avatar
mugenpower89 can only hope to improve
Re: Tire Size
my guess is they'll work but r u plannin on gettin rims?
Old Oct 9, 2007
Re: Tire Size
Well yes, I now have 185/65/14 if I go to 195/55/15 that would mean I need differant rims. I would love to get 205/45/16 but I am afraid of rubbing. Especially if I lower the car by 1.5". The 15" rims will work well, I don't want to build a race car, just a really good highway car... The car is 100% stock now, I want to make sure I thoink it all through.
Old Oct 15, 2007
mrplow123456's Avatar
mrplow123456 will become famous soon enoughmrplow123456 will become famous soon enough
Re: Tire Size
I recently took my 17" Axis rims off. I had 205/40-17 Dunlop FM901s on them and had no concern of rubbing. The car is at stock height too.
Old Oct 15, 2007
Re: Tire Size
Thanks, that's good to know. One of my concerns is that I would like to lower the car by 1.5". I'm still thinking about which way to go on this one. The lowered suspension and wheels will be the last thing I do, so I have a bit of time. If I ran into a great deal on 16" or 17" rims, that would effect which way I go. Thanks for the info.
Old Oct 15, 2007
Re: Tire Size
No problem. I have been told you can fit up to 18's under a stock civic but u have barely any tire. Just do some research on lowering and keep us informed on the car.
Old Mar 31, 2008
TheJGB3's Avatar
TheJGB3 is an unknown quantity at this point
Re: Tire Size
I would recommend the 205/45R16 (Honda Fit OE size) size if you want 16" wheels. This is a +2 fitment for the 185/65R14 OE tire and a +1 fitment for the SI 195/55R15.
Old Mar 31, 2008
silver2's Avatar
silver2 is an unknown quantity at this point
Re: Tire Size
I just went from stock 14" tires and wheels with cheap Michelin Pilot's to alloy's with 195/60/15 Falken Ziex. The tires are a bit taller than they should be so there's a little speedometer error. However, the ride is fantastic. Quiet and smooth. I couldn't believe the improvement.
When I switched from a big American sedan to the Civic, I was delighted with the stock Civic handling. If you can improve it, that's fine. For a driver, it is more than adequate. Quality tires are a must. Anything else may sacrifice ride quality although excellent handling makes it a joy to drive.
Old Apr 16, 2012
b.macfarlane's Avatar
b.macfarlane is an unknown quantity at this point
Re: Tire Size
I have a 2000 Honda civic and I just bought 15 inch rims and the tire size is 195 55 r15 . The car isn't lowered , and it's the sedan 4 door . Should I be concerned about rubbing or will they fit ?
Old Feb 14, 2015
dj84's Avatar
dj84 is an unknown quantity at this point
Re: Tire Size
Ive got a 98 civic pretty much slammed i want rims and ive got.a good deal on a set of 17s but i need to know wat tire size i need bc the rima have no tires. Can sum 1 plz help me?
Theshwartz35
Jul 17, 2015 11:13 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
muttleytm
Jul 8, 2015 04:13 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
