Engine Blew Up. Time To Rebuild.
Old Sep 24, 2007
HiPWR Racing's Avatar
HiPWR Racing will become famous soon enoughHiPWR Racing will become famous soon enough
Alternator bearing broke, shot a hole through the block. Might as well rebuild the f'er. but first I gotta take it apart. heres some pictures.
Name:	Engine Without Intake or Fuel Rail.jpg
ID:	72676   Click image for larger version
Name:	Engine Without Throttle Body.jpg
ID:	72677   Click image for larger version
Name:	Engine without Intake Manifold.jpg
ID:	72678   Click image for larger version
Name:	Engine Without Header.jpg
ID:	72679   Click image for larger version
Name:	Engine head without Distributor.jpg
ID:	72681   Click image for larger version
Name:	AEM v2 CAI.jpg
ID:	72682   Click image for larger version
ID:	72683   Click image for larger version
Name:	Distributor without cap + blaster coil.jpg
ID:	72684   Click image for larger version
Name:	Fuel Rail + Injectors.jpg
Name:	Intake Manifold, Took Forever.jpg
ID:	72686   Click image for larger version
Name:	Megan Racing Header.jpg
ID:	72687   Click image for larger version
ID:	72688   Click image for larger version
Old Sep 24, 2007
exturbo6's Avatar
Re: Engine Blew Up. Time To Rebuild.
put a b-series motor in there.
Old Sep 24, 2007
nah i'm just gonna take it apart, get a new short block, get all performance parts for the whole engine and get 300 hp all engine or at least try.
Old Sep 24, 2007
exturbo6's Avatar
man u can get a b16 atleast for 1200 or less, and have DOHC.
Old Sep 24, 2007
honestly, getting a b16 is going to do what besides give me dohc?
getting aftermarket EVERYTHING. ur telling me that my D wouldn't be faster than a b or a k?
Old Sep 24, 2007
speedfoos's Avatar
Stick with the D man. More cams aren't like more cowbell.
Old Sep 24, 2007
thats what i thought. thank youuu. and when i have a compression of 14:1 and get an all new skunk2 valve train with skunk2 cams and skunk2 intake manifold, along with a supercharger eventually im pretty sure i cna get 350 hp at least
Old Sep 24, 2007
maybe doing an H swap .. any opinions
Old Sep 24, 2007
greeen01civic4d's Avatar
stay d, go to d-series.org, ull find a new love for the d-series motors
Old Sep 24, 2007
i dont see whats so great about that site
Old Sep 24, 2007
cmon, its everything d-series, whats not to love, really tho, its an ok site, i spend more time here than anywhere, but it has a lot of good info about all things d-series, if i cant find it here, i can find it there
Old Sep 24, 2007
well. max hp i could get outta a D series is .. 250? max hp outta a B,K,H is about 400
Old Sep 25, 2007
speedfoos's Avatar
Max HP out of a D is 250? Are you talking just N/A with a blower? 250 is easy with FI man, whether it's turbo or an SC.
Old Sep 25, 2007
exturbo6's Avatar
d16turbo.org/ or come not sure
anyways, i think a b16 is better, plenty of options, and a better motor to start with..and yes fooos, i think 2 cams is alot better then 1...howveer u wanna look at it..
Old Sep 25, 2007
speedfoos's Avatar
No biggie Steve. I have no idea how to work with two cams, have only ever ****ed with SOHC Hondas, so I don't want to stray from my comfort zone.
Old Sep 25, 2007
exturbo6's Avatar
well for the amount of money hell end up spending on a d16, he can buy a b16 and play with it, and be alot more happier then a d16. more power, more fun.etc
Old Sep 25, 2007
yeah i was also thinking b18c,h22a,k20a2 .. depends on how much money i want to save up. i'm best going with h22a or b16 i think
Old Sep 26, 2007
exturbo6's Avatar
well, i mean, dont leave out the GSR motor...b18
Old Sep 26, 2007
Well, wheres a really cheap place i can find engines? the cheapest I've found is www.jdmcarboy.com -- theres b16a's with about 10k miles for 2500$.
Anything better?
Old Sep 26, 2007
exturbo6's Avatar
http://www.jaydm.com/
http://www.jspecauto.com/
http://passwordjdm.com/JDM-Honda-C201.aspx
http://www.naganojapanese.com/
Old Sep 26, 2007
is a b18b dohc?
Old Sep 26, 2007
exturbo6's Avatar
yes.
Old Sep 26, 2007
what about vtec?
Old Sep 27, 2007
exturbo6's Avatar
**** yeah..GSR motors kick ***.
Old Sep 27, 2007
exturbo6's Avatar
http://www.naganojapanese.com/engine...Honda_B18C_GSR
Old Sep 27, 2007
way tooooo expensive
Old Sep 27, 2007
dezod's Avatar
7thgen Power Maker
Go Turbo H22 FTW
Old Sep 30, 2007
sql_civic's Avatar
Really? Your alternator blew a hole in your block? How does that happen?
Old Sep 30, 2007
sql_civic's Avatar
You need to do some more research.
14:1 + 6psi boost (from a S/C) = kablooie
Blowers like 10:1 C/Rs which might get you close to 200hp on a d-series.
To get 350 HP on a d-series you need to use a turbo and set your C/R somewhere about 8:1 if you want to run on pump gas.
Old Sep 30, 2007
sql_civic's Avatar
More power = more fun? That's not true for everyone - maybe for you.
Some guys make their builds because they want to see what they can do with a certain motor. It may be SOHC, DOHC, or a damn lawn mower tractor.
There's nothing wrong with building up a D16 and trying to find what you can do to it within your budget.
