Air fuel ratio
Old Sep 5, 2007
Jza's Avatar
Jza
Jza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the rough
Air fuel ratio
What is the ideal air/fuel ratio? I've heard figures like 10 parts air, 1 part gas. Is this correct? What is the air/fuel ratio given off by a completely stock engine?
Old Sep 5, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: Air fuel ratio
14.7:1 is complete combustion (everything is expended). You dont want to run that high under load, as you want some factor of safety set into the system, NA, I think you could get away with High 12s at WOT, under boost, you want mid 11s
Old Sep 8, 2007
Jza's Avatar
Jza
Re: Air fuel ratio
So complete combustion is 14.7 parts air and 1 part gas. But idealy, you want 12 parts air and 1 part gas at WOT (wide open throttle)?
Old Sep 8, 2007
speedfoos's Avatar
Re: Air fuel ratio
For boost or NA?
Old Sep 8, 2007
Jza's Avatar
Jza
Re: Air fuel ratio
Both
Old Sep 28, 2007
andyman97's Avatar
Turbo Guru
Re: Air fuel ratio
12 anything :1 is uber rich. You won't make power that rich. I'd say mid-high 13's would be good under n/a apps. Mid-low 11's is ideal for boost, gives a good cushion of safety.
Old Sep 28, 2007
dezod's Avatar
7thgen Power Maker
Re: Air fuel ratio
12's:1 on an N/A all motor app should be fine. That will allow for some buffer of bad gas and top end runs.
juror
May 26, 2015 06:35 PM
cruisers10
May 12, 2015 10:46 PM
AFlyer
Mar 4, 2002 05:09 PM
Booohahaha
Jan 20, 2002 12:03 PM
02Si
Jan 1, 2002 11:30 AM
