1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
d15 what it worth
Old Aug 22, 2007
ridinlowhonda's Avatar
ridinlowhonda is an unknown quantity at this point
Question d15 what it worth
is it worth keeping a d15 and turboing it, what can i get out of it hp wise???
Old Aug 24, 2007
MMKennedy's Avatar
MMKennedy will become famous soon enough
Re: d15 what it worth
I'd say no, but it's all personal preference right? Some people don't like swapping, other's see it as essential. Assuming you got a 25-30hp turbo, you'd see maybe 120-130 max? Without any other modifications. For the amount of money and trouble it'd be worth, I'd still say no. I'm waiting till I can afford to do a swap, even with just a swap you'd probably be pushing more power than the D15 with the turbo...
Old Feb 21, 2008
G-reazie's Avatar
G-reazie is an unknown quantity at this point
nah not true at all...first question is the d15 vtec or is it a d15b7? ...if its the vtec model its already at like 115 - 125 horse power.. and u cant jus slap the turbo on it...it would require building it, low comp pistons, new fuel injectors for higher flow.. with a good stage 1 clutch and a few other mods u can get a good 250 hp out of that d15 ... good luck id love to see a write up on this
Old Mar 4, 2008
vega66's Avatar
vega66 is an unknown quantity at this point
Ehh iv seen stock setup turbos running 8-9psi with stock internals. Buddy of mine is running a similar setup and its been running for about 2yrs now. But either a swap or if you want to stay with the d-series (aka cheap route) you should find yourself a d16a6. Probably close to the best d-series engine you can find. Pretty sure people on here already know that the A6 block has the steel gurdel(sp?) as far as the rest of the d-series engines they have the aluminum ones. Just my 2cents
Old Mar 4, 2008
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
D15 Vtec for the win!!!!
Old Mar 9, 2008
90 hatchman84's Avatar
90 hatchman84 is an unknown quantity at this point
hey what d15 do u have. I have a 90 hatchback with a d15b2. I'm really interesed how this works for because im thinking of doing a mpfi swap on mine so i can chip it out and put on a vtec head.Well hope to hear how this works out for u.
Old May 4, 2009
ECivic19's Avatar
ECivic19 is an unknown quantity at this point
I have a D15b7, what can i do to change it to VTEC?a mini me??
Dawit Melese
Oct 4, 2015 08:02 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
deanaZoom
35
Sep 19, 2015 12:22 PM
Jrosa
Sep 14, 2015 08:24 PM
Bikergofast
Sep 12, 2015 01:36 PM
