my car revs to 1500 in neutral
Old Aug 20, 2007
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
hey guys- my car just hit 90,000 miles last week! i was so impressed about how ive never taken it to the shop for anything- even tho i did buy the car with an extended 100k mile/7yr warranty back in '01
anyway, as luck would have it- my first problem has come through.
i drive a 5spd. when i shift into neutral so that i can coast into a stop- my revs usually smoothly go down to idle- somewhere at 750 rpm. BUT NOW.. they go down to 750, then immediately kick up to 1500 and hold for about 4 or 5 seconds, then drop to 1000 (maybe 750). whats up with that? any ideas?
ive had my FIPK2 K&N air filter on for years, i just cleaned it last year. maybe its an air sensor?
Thanks
Old Aug 20, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
Re: my car revs to 1500 in neutral
IACV?
have you ever cleaned it?
Old Aug 22, 2007
ashokudu's Avatar
ashokudu is an unknown quantity at this point
Check your idle air valve.
Old Aug 28, 2007
VinhTEC's Avatar
VinhTEC is an unknown quantity at this point
Idle air control valve probably messed up. My civic was like yours it didnt have any problems untill 90k miles when my batter finaly died after 4 years lol took it long enough.
Old Aug 29, 2007
chawski's Avatar
chawski will become famous soon enoughchawski will become famous soon enough
does it continue to do this after the engine is up to temp? it could be a faulty cold start enrichment. basically what this does is raises the idle to about 1200-ish until the engine is up to temp, in order to get it to temp faster. i had to have mine replaced last year
Old Aug 29, 2007
HighBoost's Avatar
HighBoost is an unknown quantity at this point
samethin happened to mine, but i totally dont care..two days later..it got normal.. lol
Old Sep 3, 2007
SOHC's Avatar
i noticed that if i turn my steering wheel, the revs drop too.
i took it to the dealer- turns out that the wires from my power steering pressure sensor switch were worn out. they repaired the wires and im good to go!
mikemc422
Aug 9, 2018 05:41 PM
Blaster30
Apr 22, 2015 12:21 PM
mattskav
Nov 8, 2001 10:44 PM
locozoko
Nov 8, 2001 06:33 PM
Guy01
Nov 6, 2001 03:25 PM
