higher after lowering
Old Aug 16, 2007
kcari's Avatar
when the guys at the shop unjacked my car it looked like it was higher than factory springs after installing H techs. When I drove home they dropped to the minimal drop that was advertised. Is this normal? Someone said my bushings probably are broken but my car drives normal. Others say just needed time for the springs to snap into place/settle. The mechanics at the shop didn't seem to know why it was higher than before - so they ordered me S techs.
Old Aug 16, 2007
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
Re: higher after lowering
It's normal. They need time to settle.
Old Aug 16, 2007
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
yup^
Old Aug 16, 2007
kcari's Avatar
if my bushings are broken or torn would i know it?
Old Aug 16, 2007
02BLKCIVIC's Avatar
look under the car at the control arms
Old Aug 16, 2007
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
I am sure that would create a noticable noise...
Old Aug 16, 2007
02BLKCIVIC's Avatar
not always. Your CV joints may click or make a sounds but probly not the bushings
iv replaced mine after i was lowered 4inches and switched suspentions...
look under the car at the control arms youll see it ripped or torn
Old Aug 16, 2007
kcari's Avatar
what exactly am i looking for? and would handling etc for my car be different? I've been driving around since Tuesday and so far so good.
Old Aug 17, 2007
drew22mader's Avatar
There is gl@ss in my @SS...
You do know that this isn't normal, after using lowering springs you should notice an immediate drop, shouldn't be any higher at all. Springs do take time to settle but should already be low. Sounds to me like you ordered different springs for another car, say the RSX. Torn bushings will have no effect on how low the car goes. But turn your wheels to the right and left and look inside the wheel well. You should be able to see if the boot is torn.
Old Aug 17, 2007
02BLKCIVIC's Avatar
lol good point^ iv never heard of H techs
Old Aug 17, 2007
ryox82's Avatar
They sell them on procivic.com
Old Aug 17, 2007
02BLKCIVIC's Avatar
cool^
TEIN H-Tech springs are similar to the S-Techs, but offer a more comfortable ride and less of a ride height drop. The H-Techs are made from a new material called "Vanadium", which is very light and increases flexibility.
Key Features:
Designed specifically to fit each car for maximum performance.
About a 1 inch drop for a more attractive appearance.
Comfortable ride quality is still maintained by using the OEM bump rubber and noise protection sheet.
Old Aug 17, 2007
ryox82's Avatar
I guess they are Tein's answer to Pro-Kit. Wich is what is going onto my car with the blues tonight after work
Old Aug 17, 2007
kcari's Avatar
well i dont understand why it was really high and then dropped down when i got home. I'll find out tomorrow though.
How much would torn bushings cost to replace?
Old Aug 17, 2007
greeen01civic4d's Avatar
happens to me every time i lift my car at work on the lifts there, it settles after a few miles, the struts just need time to settle, its perfectly normal.... i wouldnt sweat it
Old Aug 17, 2007
ryox82's Avatar
I can confirm this is normal. I was just at the shop putting in my pro-kits and tokicos. After we set it down i was like...****...it looks the same lol. We went and had a couple beers in the office and chilled, then I went home...I noticed a HUGE increase in handling...alignment wasnt even off beleive it or not. Lo and behold, when I pull into sevs to get some aleve, I can now see its about two fingers or a little less. (thought pro-kit was less of a drop?) Enjoy the ride!!
Old Aug 17, 2007
give it more time, ull see it settle more, mine is still settling, after almost a year(new struts 8 mos ago
Old Aug 17, 2007
kcari's Avatar
thanks guys, ihave a 4 o clock appointment to install new S techs!
but hey im sort of lucky it looked higher in the beginning or else they wouldnt have changed me S techs! But lets just hoping nothings wrong with my bushings...
and is it normal to hear the springs during driving low speeds?
Man my springs are really squeeking and squacking when i'm driving below 5 mph on my driveway or street. But at 35 and top speeds rides fine...
Old Aug 18, 2007
is it front or back, and do u have a camber kit???
Old Aug 18, 2007
kcari's Avatar
its probably the back that is squeeking at low speeds and no i don't have a camber kit yet because they told me to drive on the S techs for a week and then come back. I didnt need one for the H techs (.7 and .8 inch drop)
so after they install the S techs today and get an alignment they should be able to tell me if I need a camber kit and new bushings....
Old Aug 18, 2007
ryox82's Avatar
Ehh I dunno, we put in the pro kits and just made sure that the sprins were seated correctly, no popping, no squeeking, nothing
Old Aug 18, 2007
kcari's Avatar
everything is fine... they installed the S techs and they were low and settled even more. They didnt mention any torn bushings or anything like that so I'm good?!
Old Aug 18, 2007
u WILL need a camber kit, even for a .7 inch drop, for any drop u will need a camber kit, unless u like buying tires, a lot, it will **** up ur camber, and there is no adjustment on the rear for our cars from the factory, im only on a 1.5 inch drop, and i needed a camber kit, tires will get noisy, then steel, then bang, blown tires... do urself a favor, get a camber kit, get an alignment, ull thank me, and urself for it. if u get an alignment, then get a camber kit, ull have to repay for the alignment, costing u 50-100 bucks each time(depending on where u go), read the diy on lowering spring install, itll tell u the same thing. what happens when u drop ur car is, the top of the tire starts pointing inward like this / \ , which is what camber is, which wears out the insides of ur tires quicker than normal because the weight is on the inside of the tire, not equally distributed throughout the tire, which would provide even tire wear.... i have had this problem even with a camber kit(hit a curb, which will knock out ur alignment), so please, please, get a camber kit, and save urself a headache.... thanks for reading
Old Aug 18, 2007
kevinking's Avatar
kevinking is an unknown quantity at this point
Give it a few days...
Old Aug 19, 2007
redem2's Avatar
redem2 has a spectacular aura aboutredem2 has a spectacular aura about
believe it or not the h-techs actually cost more than the s-techs. i'm still waiting on my h-techs from showstoppers. had the prokit before the wreck and my wife keeps scraping the underside of my front bumper, so hopefully the h-techs will be a bit higher. we'll see how mine work out. but yeah, i wouldn't trust anyone working on my car. after number accounts of dumbass mechanics forgetting to put bolts and nuts back on i kinda learned my lesson. it's better to diy.
Old Aug 19, 2007
kcari's Avatar
i would love to do it myself but i seriously lack the skills...
but yes, I will get a camber kit this saturday because the shop wanted me to drive 1 week to let the springs settle THEN get the alignment THEN get the camber kit. how much would a camber kit cost btw? Front and back?
thanks
Old Aug 19, 2007
redem2's Avatar
i think you want to install the camber kit before you get an alignment. the kit should cost around $160.
Old Aug 19, 2007
kcari's Avatar
oh nice! i have about 400 bucks saved up should camber kit shouldn't be a problem then, and is it pretty universal or is there ones to designed for my car?
And would i need on all 4 wheels or what the mechanics tell me?
Old Aug 20, 2007
ryox82's Avatar
i would get it for all four, the fronts arent expensive at all. Granted my friend had a tool to keep the camber in the front zeroed out but you dont know if over time if it will get out of whack from settling. Also, the front kit is very cheap compared to the rear anyways, might as well get both. One less thing to buy if you want to go lower in the future
Old Aug 20, 2007
kcari's Avatar
do they have to remove the tires/wheels when installing the camber kit?
is it normal to hear my springs while driving really slowly? I tend to drive really slowly in the alley because there are kids playing back there, and i notice/hear my springs, its nothing major but i do notice it. i cant really describe it, i dont want to say its a squeeking noise because its not.
