Motul brake fluid in stock!
7thgen Power Maker
RBF600 DOT 4 fluid in stock at Dezod by the case or by the bottle.
http://www.dezod.com/pd_motul.cfm
100% synthetic, RBF 600 FACTORY LINE is a polyglycol-based brake fluid exclusively designed for races. Developed to resist high temperatures and wet-weather conditions, RBF 600 has a high dry boiling point of 312°C and a wet boiling point of 216°C. This ensures effective braking under extreme racing or rainy conditions. Couple this with its outstanding anti-vapor lock performance, RBF 600 has become a well-trusted brake fluid in many races.
SPECIFICATIONS
Product RBF 600 FACTORY LINE
Feature 100% synthetic, polyglycol-based. Has extreme thermal resistance and stability.
SAE/DOT Standard FMVSS 116, DOT4 & SAE J1703
Specification —
Maker's Approval —
Compatibility All types of hydraulic actuated brakes and clutch systems (not to be used with silicon-based and mineral-based brake fluids).
SPECIFICATIONS
Specification —
Maker's Approval —
Re: Motul brake fluid in stock!
Dezod got a question. I've always wanted to upgrade to motul brake fluid. But the one you carry seems to have such a low dry and wet boiling point.
My buddy just recently introduced me to Valvoline Synpower and it has a dry boiling temp of 503F and wet boiling temp of 343F.
http://www.valvoline.com/products/Va...ke%20Fluid.pdf
Is that the only motul brake fluid there is? Because I always hear good stuff about that company, but it seems weak compared the valvoline.
7thgen Power Maker
mattdoc
Mar 14, 2017 12:10 PM
RIPSAW
Nov 6, 2015 04:36 AM
