No start, weak spark, belt noise... Any ideas?
Old Aug 14, 2007
Cousin_Joe's Avatar
Cousin_Joe is an unknown quantity at this point
Unhappy No start, weak spark, belt noise... Any ideas?
I have a 94 Civic LX 1.5L 16V with about 150k miles. I let it sit in my driveway while I was out of town for almost 3 weeks. I came back to start and no luck. It just cranks and cranks with the belts making a lot of squeal. I smell gas at the tail pipe, and loosened the bolt on the outlet side of the fuel filter and gas sprayed out. I checked for spark and it seems really weak. Yellow-Orange spark, definitely doesn't seem as hot as it should. I checked the ICM according to Haynes, and all connections came back in spec. I checked the coil, and the secondary resistance was 1.2 ohms (good range 0.6 - 0.8?). Bought a new coil from Adavanced and it checks out exactly the same. I put on new cap/rotor/wires/plugs about 2000 miles ago. Resistance in wires checks out too. The main relay appears good, 3 clicks. I can hear the fuel pump prime and the ECU light turns on/off with the key on. The cam is rotating when it cranks, and pulled the valve cover off for a quick check of the timing belt, but it seems good too.
I can't figure this one out. I'm two days into this, and hoofing it. Does anybody have some suggestions that I haven't tried yet? Everything was fine before I left, no problems at anytime starting all summer long. Thank you!
Old Aug 14, 2007
02civic21's Avatar
Ricky Bobby style, IWGF
02civic21 is a jewel in the rough02civic21 is a jewel in the rough02civic21 is a jewel in the rough
Re: No start, weak spark, belt noise... Any ideas?
change the oil? take the valve cover off and the spark plugs out and let it sit for a day to dry out. reinstall and reattempt start
Old Aug 14, 2007
Cousin_Joe's Avatar
Change the oil? Not sure where you're going with that. I can try letting the plugs dry out better.
Old Aug 14, 2007
02civic21's Avatar
its just something good for the car since you let it sit for three weeks. but hey go ahead and do whatever.
mistermenphis22
Apr 3, 2016 08:06 AM
tylerswire
May 6, 2015 12:16 PM
twtron
Apr 17, 2015 12:09 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
black2k1vtec
Dec 6, 2001 09:49 PM
