DIY Manual Transmission Service Help..
Ok well my 02 civic is got 41000 on it so i think its time to do a tranny service on it.. Can someone tell me how many quarts it holds and the best kind of fluids to put in it?? Also whats the easiest way to do it on a 02 civic lx????And do i need to replace a filter or anything??thanx
Re: DIY Manual Transmission Service Help..
Thanx bro for tha help...Anyone else?? Also how do u drain it?? IS there a plug or do u just pull the pain like u do on some auto transmissions?? And does anybody know if the filter needs to be replaced or if there even is one on this??
There isnt a filter on the manual tranny. there are two holes, one for filling and one for draining. remove the filler bolt first then the drain bolt. you should be able to recognize them from under your car, if not you will have to find a picture somewhere...
#14 is the drain plug.. i believe you use #10 to fill it back up
there is a DIY on here on how to drain/refill your MTF...
there are basically two bolts on ur tranny.
the top and bottom one.
unscrew the bottom one and drain it, and then screw the bolt bak on.
then unscrew the top bolt and put somre more in there.
search for the DIY
search for the DIY
https://www.civicforums.com/forums/7...ssion-oil.html
theres one with pixs, but heres a quick search
I just use honda MTF or acura MTF. Just fill it up until it's up to the threads of the fill hole and pouring out a little bit. Also, I don't know if this applies to the d17 tranny, but on the k20a2 tranny, it's a lot easier to fill up through the hole for the VSS sensor.
xRiCeBoYx
I just replaced my manual trans fluid yesterday in a 2005 Civic LX I got nearly 2-weeks ago. The odometer had 56,000 miles and there was no evidence that the previous owner had service done to the trans. I found a really good parts department at a Honda Dealer that sold me the HONDA MTL fluid for $2.75/qt. I've read posts about other parts departments that regularly gouge the DIY customers.
I shined a flashlight into the old fluid and noticed quite a collection of fine bronze/metal particles in the fluid. I know that this is normal for a first time fluid change. I won't be changing the fluid at 60,000 mile intervals as the owners manual suggests. I'll be changing the fluid every 15,000 miles. I don't agree with any of the service intervals in the owners manual. Ten-thousand miles between engine oil changes is insane! Even 5,000 miles for severe service is too long to run engine oil.
Took the car out for a test run after swapping the fluid and immediately noticed how much smoother the trans shifted. Big difference.
Thanks for updating us bro ... was definitely waiting for someone to tell me if they noticed a difference or not ...
One more question .. is transmissin oil/ fluid and DIFFERENTIAL OIL the same thing ?
14 Hours Ago 05:18 PM
I went with the HONDA MTL because I don't want to risk voiding what's left on my warranty. I also found a synthetic MTL produced by Red-Line that is specifically designed for Honda and Accura transaxles. I've used synthetics in my motorcycles and other 4-wheelers and found them to be way better than petroleum based oils/fluids. Keep in mind that synthetics are way more expensive, but IMO it's worth the cost.
beantech
Jun 15, 2015 07:09 PM
jackshepardjr
May 24, 2015 09:53 PM
