Dezod v3 kit + kpro = 185.5 HP Updated w/ dyno sheet
Old Jul 10, 2007
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
Talking Dezod v3 kit + kpro = 185.5 HP Updated w/ dyno sheet
The results are 185.5 HP and 170 ft/lb of torque.
Dezod MotorSports S1 Turbo
RSX-S 310cc Injectors
2.5” Turbo Back Exhaust w/ Cat
Hondata K-Pro
The yellow was the first run and the green boxes where the final run.
Old Jul 10, 2007
speedfoos's Avatar
Re: Dezod v3 kit + kpro = 185.5 HP
Congrats man, that's some decent numbers. What psi were you running at, 6?
Old Jul 10, 2007
dopes6070's Avatar
the stock 5.88 PSI WG spring
Once i get my built engine in look for 300+ Hp
Old Jul 10, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
nice man, too bad u didnt get ur head pnp'd before this install.
Old Jul 10, 2007
DsevenEm2's Avatar
This is Myspace
nice good job, hows it pull?
Old Jul 10, 2007
LogicWavelength's Avatar
7th Gen Photographer
LogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of lightLogicWavelength is a glorious beacon of light
Makes me wonder... i pulled 23 more on 4psi higher boost. So... was it the fact it was 95º when i tested? Or is it more to do that I'm only using an E-Manage and no fancy Dezod parts... LOL
Old Jul 10, 2007
kileryoyo's Avatar
kileryoyo is an unknown quantity at this point
logic what size turbo are you using? If you are using a t25 that is the reason right there but if you are using the same size as the t3 dezod uses then it may be the temperture and the emanage.
Old Jul 10, 2007
andyman97's Avatar
Turbo Guru
Swap an ex head and you could expect to be over 200 whp at the same boost level.
Old Jul 10, 2007
dopes6070's Avatar
Im leaving this engine stock. The built one is getting all the goodies. I think im gonna keep the A1 head since I have talked to Crower and they are having me send in a spare A1 cam to design a Non-Vtec cam for us. Is the head core any different? I thought it was just the valvetrain. If the core is the same shouldn't they both flow about the same provided the same cam profiles?
I was tuned last Saturday which was about 85 degrees. The car pulls amazingly hard for such low boost. Whats really awesome is that it drives like stock but with WAY more power (well except for the open dump tube which sounds like a jet taking off). Im having that welded in tomorrow. Idle is perfect and no CEL.
Old Jul 10, 2007
andyman97's Avatar
Turbo Guru
Flow wise, I haven't seen an analysis of the portflow for each head side by side so I can't say. But you get much more airflow on a stock vtec head than a stock non vtec head when vtec is engaged. If you want to do a comparison of heads, compare mine to hector's. He's running an a1 head with a cam. On 21 psi with race fuel and a 75 shot, I believe, he hit 43- something. On pump gas with my a2 head and stage 3 cam, I hit 375 whp. There are alot of variables but I think overall you'd be better off with a vtec head.
Kpro is bad ***, isn't it?
Old Jul 10, 2007
dopes6070's Avatar
One thing I can say is that im really glad I went with a stand alone just because of the way it runs. I also can't wait to use the boost by gear feature.
Im really looking for the low 300 hp range on pump gas with no nitrous. I may pick up an A2 head if I find one cheap enouph. Otherwise I will just stick with the A1.
Old Jul 10, 2007
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Nice numbers!
Old Jul 10, 2007
Matteo's Avatar
Matteo will become famous soon enough
wow man thats insane! very nice. u should race a new stock SI civic and see if u can beat it
Old Jul 10, 2007
rick1574's Avatar
rick1574 will become famous soon enough
nice numbers. post up some vids and track times. i've been bouncing between doing an n/a tune (i know, i know, not a lot of power) or boosting. but since my car is DD and i drive about 400 miles a week so i'm not sure boost is the best thing for me.
Old Jul 10, 2007
dopes6070's Avatar
Re: Dezod v3 kit + kpro = 185.5 HP Updated w/ dyno sheet
Im waiting to go to the track when I get some decent tires up front. I will also need to get some good axles and a new clutch before I get serious about the strip.
Traction sucks with all season grandma tires...
Old Jul 10, 2007
ex2k3's Avatar
diamonds she will pretty much have to
ex2k3 is a jewel in the roughex2k3 is a jewel in the roughex2k3 is a jewel in the rough
sweet, looks like that kit i sold you gave some solid numbers. you got it setup pretty quick too.
Old Jul 10, 2007
dopes6070's Avatar
yup thanks again
Im definatly putting it to good use
Old Jul 10, 2007
andyman97's Avatar
Turbo Guru
You're not making near enough power to need axles. Mine are still holding up fine.
Old Jul 10, 2007
yup thanks again
Your dyno shows 2 rund.
What changes has been done to a tune to gain those few extra ponies?
Old Jul 10, 2007
TRIZ's Avatar
Looking good.
Old Jul 10, 2007
RHCP0801's Avatar
any engine bay pics?
Old Jul 10, 2007
dopes6070's Avatar
Your axles are fine with 375 HP?? If so I guess I wont worry about getting them.
the first run was with it pretty rich thats y power was so much lower.
The turbo is actually back out right now getting a dump tube welded into the DP. I will take pictures after I get it back in.
Old Jul 11, 2007
andyman97's Avatar
Turbo Guru
I have been boosting this car on 3 different turbo setups ranging from about 170 whp to 375 whp on the same tranny and axles over the course of about 4 years. Only thing I've done was a clutch upgrade about 4 years ago.
Old Jul 11, 2007
dopes6070's Avatar
Awesome, sounds like I don't have to worry.
Old Jul 11, 2007
exturbo6's Avatar
nice numbers. no pics?
Old Jul 11, 2007
dopes6070's Avatar
The turbo is off for a couple days till I can get the wastegate dump tube welded up. Finding someone to tig weld it for under $100 is turning out to be harder then I thought.
Old Jul 11, 2007
exturbo6's Avatar
what happened to the s2k u had or got or whatever. and did i seel u that tsi kit like 2 years ago? if so, now ur back to modding the 7thgen? lmfao
and now ur going to do a fully build motor..lol
Old Jul 11, 2007
dopes6070's Avatar
I get bored very quickly LOL. I sold the s2k because black paint is a bitch and because it was SOOOO expensive to own. This time I’m doing everything right on the vic.
Old Jul 11, 2007
dezod's Avatar
7thgen Power Maker
Congrats on the numbers! Dezod does it again...
Old Jul 11, 2007
dezod's Avatar
7thgen Power Maker
All in the design sir.
You have Hyaboosta's old SFP kit right?
