alright guys, need alittle help
Old Jun 28, 2007
zzsupermanzz15's Avatar
zzsupermanzz15 is on a distinguished road
i just installed, Tein SS coilovers on my 2004 coupe. and everything went fine. its when i turn left or right i hear a pretty loud clunk noise. it seems like its coming from the driver side. my friend and i, took everything out and everything seemed fine. i dont know wats wrong, someone help me!!!
Old Jun 28, 2007
KaOtIcCiViC's Avatar
KaOtIcCiViC is an unknown quantity at this point
Re: alright guys, need alittle help
Are you certain you have everything screwed tight?? I had a similar problem when I had my Vic. I noticed that the top nuts weren't tight. I would screw everything on and make sure you lube a bit, then go back, double-check and tighten up again.
Old Jun 28, 2007
spoonEM's Avatar
omgwtfbbq mod.
did you position the spring correctly on the front? If not, thats the clunk. You have to make sure you clock the spring in the right location before tightening it down otherwise it will keep clunking.
Old Jun 28, 2007
well, i did tighting everything down pretty good, the bolts shouldnt be loose. what do you mean, "clock the spring"?
Old Jun 28, 2007
VNlilMAN's Avatar
The Standard One
you know... clock as in punch it
j/k... i believe it has something to do with the top mounts.
Old Jun 28, 2007
spoonEM's Avatar
omgwtfbbq mod.
i meant index the spring. make sure its sitting in the top mount and in the lower spring seat properly, if its not, theres your problem.
Old Jun 28, 2007
i think it is, not sure. going to take it to the shop later and see if they can solve it. is it a common, problem among civic's?
Old Jun 29, 2007
Ti71's Avatar
Ti71 is an unknown quantity at this point
Make sure you have the top mount bearings installed.
Old Jun 29, 2007
VNlilMAN's Avatar
The Standard One
i think teins only work with 01 upper mounts, you need to get them.
but then again, i am drunk, what do i know...
Old Jun 29, 2007
dj02's Avatar
you know what works, as this is a very very very old topic. and yes 01 upper mounts is what you need. if you need more information just do a search this was covered since 02.
Old Jun 29, 2007
oh dang really?.. how much do 01 top mount goes for?
Old Jun 30, 2007
TemjinX2's Avatar
If you have the newest version of the Tein SS from Tein. You dont need 01 top mounts. All the new versions of the Teins come with two sets of spring seats. One set will work for 01-02 top mounts and the other set should work with the 03-05.
everyone told me the same thing when i was getting my tein basics install on my 04. biggest waste of money, since later we found out the spring seats i had would only work with my 04 top mounts.
Old Jun 30, 2007
TemjinX2's Avatar
this is more likely your problem. Unless your using the wrong set of spring seats.
Old Jul 1, 2007
hey, thanks guys the problem was that i installed it wrong. thanks again though
lilrob1213
37
Jun 29, 2015 06:45 PM
wholt0
Transmission
Jun 11, 2015 11:15 PM
jordan1794
Jun 11, 2015 09:14 PM
kportie20
Jun 5, 2015 04:18 PM
Brianmc1995
Jun 4, 2015 07:51 PM
