alright guys, need alittle help
i just installed, Tein SS coilovers on my 2004 coupe. and everything went fine. its when i turn left or right i hear a pretty loud clunk noise. it seems like its coming from the driver side. my friend and i, took everything out and everything seemed fine. i dont know wats wrong, someone help me!!!
Re: alright guys, need alittle help
Are you certain you have everything screwed tight?? I had a similar problem when I had my Vic. I noticed that the top nuts weren't tight. I would screw everything on and make sure you lube a bit, then go back, double-check and tighten up again.
did you position the spring correctly on the front? If not, thats the clunk. You have to make sure you clock the spring in the right location before tightening it down otherwise it will keep clunking.
i meant index the spring. make sure its sitting in the top mount and in the lower spring seat properly, if its not, theres your problem.
you know what works, as this is a very very very old topic. and yes 01 upper mounts is what you need. if you need more information just do a search this was covered since 02.
If you have the newest version of the Tein SS from Tein. You dont need 01 top mounts. All the new versions of the Teins come with two sets of spring seats. One set will work for 01-02 top mounts and the other set should work with the 03-05.
everyone told me the same thing when i was getting my tein basics install on my 04. biggest waste of money, since later we found out the spring seats i had would only work with my 04 top mounts.
lilrob1213
37
Jun 29, 2015 06:45 PM
jordan1794
Jun 11, 2015 09:14 PM
