2007 Civic Low Oil Pressure
Old Jun 13, 2007
caucano's Avatar
caucano is an unknown quantity at this point
Hi all,
I just recently (jan 07) bought my 1st car, a 2007 civic Lx. I love it, aside from the fact that the low oil pressure light keeps coming on randomly (well not randomly, it seems to come on when I have the air conditioning on for a while) I live in AZ so the air conditioning is crucial. I have taken it to my local dealership three times already. The first two times they told me it was fixed; I was told it was an electrical problem in the sending unit. But the light came on again last weekend and I took the car back to the dealership and complained. Now they tell me that they got in contact with Honda Engineers (they should have done this before) and that the oil pump needs to be changed.
As this is my 1st car, I am learning a lot and wanted to get your input on what I can expect from the dealership. I mean, I'm sure they'll tell me this time that its fixed, but if it comes on again what I am to do? Is there not some law against getting a bad new car? Are there others out there with the same problem? Also, is the fact that the oil pump need to be changed a serious issue?
Thanks for your inputs.
Old Jun 13, 2007
Boilermaker1's Avatar
Jap-Euro Fusion
Re: 2007 Civic Low Oil Pressure
Anything can be defective, it sometimes takes a little while for it to show. If they're changing the oil pump.... you got a big problem, and there's no guarantee it fixes it. That light doesnt come on until there is ZERO oil pressure. Force them to rip out the girdle and the rod caps and make sure you didnt spin a bearing. If you had no pressure and the crank made contact with a bearing, the whole motor is ****ed. I'd make em change the entire short block out anyways, you'll probably have to fight with them, but its a fight worth while. Every state has a lemon law, you'll have to look up your state's requirements for declaring a car a lemon.
From experience, dealers are morons, and they tend to play a guessing game, trying simple things and claiming its fixed, rather than actually trying to trouble shoot the actual problem.
Old Jun 13, 2007
caucano's Avatar
Boilermaker, thanks for your reply. I had not actually worried about the oil pressure being actually low since I was told the dummy light came on by mistake and that there was nothing wrong with the oil pressure. They even took measured the oil pressure with a gauge and it was alright (so they say). Damn, not having full knowledge of the insides of the car is really going to hurt me. I'll check out the lemon law thanks
Old Jun 13, 2007
DaMadScientist's Avatar
Pwning Noobs 24/7
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
wht i would do would be fight for a new car
Old Jun 13, 2007
Jap-Euro Fusion
Yeah, telling you this saves them the trouble of swapping out the motor because they think that you dont know whats going on with it. I would fight em tooth and nail to yank the thing apart and show you the bearings, or make em replace the bottom end.
That switch going off more than once, especially if its more than one switch, is not an electrical fault, thats a problem. This gauge they hooked up.... were they driving around with it? Or did they idle it on a lift.... cuz thats 2 different things.
Old Jun 14, 2007
caucano's Avatar
Can I just go and fight for a new car? And about the oil pressure, I think they tested under idle and accelaration...not too sure about crusing...I'd have to check the receipt. I don't mind asking to see bearings but this is all new to me and learning takes a while; don't want to look like a fool when they show me busted bearings and I just smile like an ***
Old Jun 14, 2007
Pwning Noobs 24/7
i would and just save the headaches cause you dont know if this will lead to any other premature failure of other engine parts
Xuhme
21
Aug 7, 2023 03:40 PM
mattdoc
Mar 14, 2017 12:10 PM
LionSpratt
Jan 29, 2017 11:07 PM
usajags84
May 10, 2015 08:11 AM
alexkharden
Apr 23, 2015 07:13 PM
