AC Recharge kit overcharged my system! What now?
Old Jun 9, 2007
bakertime's Avatar
bakertime is a jewel in the roughbakertime is a jewel in the roughbakertime is a jewel in the rough
I picked up one of those kits at PepBoys the other day, and got around to doing it today. Followed the directions perfectly, and the pressure gauge said I was on the low end of the recommended pressure, so I kept adding more. Next thing I know, I'm two cans down, and it read barely any change in pressure. I'm pretty sure it's very overcharged though, because it won't hold any RPM (even accelerating) when the AC is on. I noticed afterwards that the sticker on the frame says that the recommended charge is 19.X oz, and each can I put in was 14oz.
So yeah, enough said...I'm just lucky I didn't break anything yet. My question is, what is the best way to get this fixed? Any way I can discharge some pressure safely? It's pretty clear the pressure gauge they have is total crap (which I'm pretty pissed about), so I can't use that to accurately check.
I'm planning on contacting the company and raising hell, but in the mean time, what's the best way to go on this one?
Old Jun 9, 2007
bakertime's Avatar
Re: AC Recharge kit overcharged my system! What now?
R-134a isn't illegal to discharge. R-12 is probably what you're thinking of. Going off the name (Also known as HFC-134a), it's also used in airsoft guns as a propellant, where it's commonly discharged into the atmosphere.
Old Jun 9, 2007
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
u know the car is supposed to be running while you recharge the a/c right?... discharge the a/c with the car off... start the car back up.. keep doing it till the charge is in the green area... you check the pressure of the a/c while the car is running on the low side.. thats what probably happened.. you charged it with the car off
Old Jun 9, 2007
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
you dont charge an ac system with the car on. with the snap on machine i use almost every day, you discharge with the car off. when you recharge, you pull a vacuum on the system, hold it, release the vacuum, and charge it. after it is charged, you close the high side port and guage, start the car, open the high side guage, clear the guages, check your pressure, **** the car down, and disconnect the a/c machine. you only start the car while charging if the ac system wont accept any more freon. then you start the car and cycle the compressor long enough to make room for more freon.
Old Jun 9, 2007
bakertime's Avatar
Directions said to do it with the car on, so I did. It reads a WAY higher pressure when off, then on. I guess my question is more of HOW do I discharge it. The new stuff has this green UV dye to detect leaks, and it's going to spray everywhere.
Old Jun 9, 2007
dude.. i know you dont charge the a/c system with the car on.. i have used the snap-on and a few other brand machines before...
but my question is did you read his first post or just mine... he used the store bought recharge kits you can find at almost any walmrt, pep boys, autozone and so forth... i have also used those store bought kits myself.. those kits only connect to the low port side.. those kits require you to have the car running with the a/c on to full while u charge it...
so i am responding accordingly to his situation and the type of kit he is using.. not everyone can afford a stand alone unit.. espcially one that uses both high and low port connections
Old Jun 9, 2007
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
i dont think you should say things like this on a forum. did you ever stop to think that your using some different type of recharging kit? Most DIY kits require that you charge the a/c with the cars engine running and the a/c controls to the highest setting. You check the psi on the low side port with the supplied gauge it should be between 25-45psi to be considered filled. You do not recharge an a/c system through the highside port. The 7th gen civic takes about 17.6-19.4oz. While recharging you should shake the can vigoursly and remove the guage once in a while between to make sure the ready you are getting is correct.
Old Jun 9, 2007
Mr_Plenty's Avatar
and another thing your not suppose to discharge it into the air, so you can go to an a/c place and they'll discharge it for you...possibly for free
Old Jun 9, 2007
RHCP0801's Avatar
with the machine i use at work needs to have the car off
Old Jun 9, 2007
bakertime's Avatar
Thank you for reading my post! I guess I'll give my mechanic a call and see if they can check the pressure/discharge. I'm pretty sure the gauge that came in the kit is worthless in terms of accuracy. It tells me it's all set, but somethings definitely wrong. I appreciate the help!
Old Jun 10, 2007
D16Z6_owner's Avatar
D16Z6_owner is an unknown quantity at this point
dude the atmosphere will be fine. those tree huggers out there are lying. just get one of those tire pressure guages with the pin on the back and use lots of rags and newspaper i guess
Old Jun 10, 2007
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
^^^jeez man , you probably dump coolant and engine oil into the sewers too. have some courtesy to your kids.
And also do not just push the nozzle and use "rags and newspaper", its refridgerant, which means it can cause severe burns which could be fatal.
Just bring it to the shop and they can discharge it for you. You'll probably spend more money on gauges and stuff when you can get an accurate discharge for less.
Old Jun 10, 2007
a smart shop would evac it for free seeing as how they can sell it to other customers. plus they can acurately tell you how much was in it. if you used a 14 oz can, you probably only got around 12 oz out of it.
Old Jun 10, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Honestly you don't know what your doing, and before you lock up your compressor and have to spend a ton of money in repairs i would HIGHLY recommend you take it in to someone who KNOWS what they are doing.
Old Jun 10, 2007
rice4lyfe's Avatar
oh ya, and both R-12 and R-134a is illegal to discharge into the atmosphere. They are both ozone depleting substances.
Old Jun 10, 2007
thats wrong. time for a chemistry lesson- r12 is a chloroflourocarbon (CFC) in which the chlorine part steals an oxygen atom from O3 (ozone) which in turn creates O2 and a fully stable cholrine atom. on the other hand-R134a is a hydroflurocarbon which does not contain chlorine making it safe to evacuate into tha atmosphere. the only problem is that expanding refridgerants can cause freze burns
Old Jun 10, 2007
Old Jun 10, 2007
hey at least im goin to college for free
Old Jun 10, 2007
cinaibur's Avatar
cinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nice
^^^ lol... people always hate when you drop some knowledge on their ***
Old Jun 10, 2007
bakertime's Avatar
Thanks guys, I will absolutely be taking it to a mechanic. Just for kicks:
epa.gov on retrofitting from r-12 to r-134a:
R-134a Refrigerant
Toxicity, Flammability, Corrosion
R-134a is regarded as one of the safest refrigerants yet introduced, based on current toxicity data. The chemical industry's Program for Alternative Fluorocarbon Toxicity Testing (PAFTT) tested R-134a in a full battery of laboratory animal toxicity studies. The results indicate that R-134a does not pose cancer or birth defects hazard. In addition, R-134a is being used in metered dose inhalers in Europe.
OEM engineers and chemical manufacturers have examined the flammability and corrosivity of each potential R-12 substitute. Like CFC-12, R-134a is not flammable at ambient temperatures and atmospheric pressures. However, R-134a service equipment and vehicle a/c systems should not be pressure tested or leak tested with compressed air. Some mixtures of air and R-134a have been shown to be combustible at elevated pressures. These mixtures may be potentially dangerous, causing injury or property damage. R-134a is not corrosive on standard steel, aluminum and copper samples.
When handling R-134a, as with any other chemical, service techs should be sure to work in a well ventilated area. It is never a good idea to inhale any vapor to such an extent that it replaces the oxygen in your lungs.
And for airsoft guns :
Since this is used as a propellant, it is discharged into the atmosphere each time an airsoft gun is fired.
http://www.airsplat.com/Items/GG-HFC134A.htm
I think it's safe to say that it's OK to discharge HFC/R - 134a into the atmosphere in terms of it's ozone depletion. On the flip side though, it can be detrimental as far as global warming goes. Try telling that to me last winter...heh.
Old Jun 10, 2007
jbrown59's Avatar
CIVIC USER
jbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trusted
Now tell me this, did you know this before you released the ac stuff or after the fact....
Old Jun 11, 2007
bakertime's Avatar
...I didn't release any.
Old Jun 12, 2007
HondaGrL98's Avatar
HondaGrL98 is an unknown quantity at this point
ok, so i was reading every one elses comments. I have a 98 civic and need to recharge my a/c. I know where & how to do it, but am a little unsure on how much stuff(134a) i should put in. How do you know if you put too much in, if the gauges don't read right on the cans?? Also, are the cans as effective as taking it to a shop & having a machine do it? b/c my dealership wants 175$ to do it. What a rip off! help ...
Old Jun 12, 2007
the shop does basically the same thing. exept with a more expensive machine. i would test the guage before using it.
Old Jun 12, 2007
HondaGrL98's Avatar
k thanks. Is one can usually ok ?
Old Jun 12, 2007
bakertime's Avatar
It depends on how low you are. For me, the total charge reccomended is 19 something ounces, but the cans are 14, so keep that in mind. Basically, if the can messes up, then you're SOL, and have a chance at causing more damage due to higher pressures. After having this experience, I'll never use a can again, but that's just me. The kit cost $35, and now they're evac'ing it, cleaning, and then putting the proper amount back in. I would definitely have a shop do it, because it is NOT the same. Call around for some quotes, and hopefully you can get it for less (the dealership is probably the most expensive).
cukaracha
30
Jul 26, 2015 12:01 PM
chrisjackson321
Jul 12, 2015 03:00 PM
beeemerdude
Jul 10, 2015 09:22 PM
