complete dismantle
complete dismantle
ok... so i had some noise coming outta my tranny... it happens only under forward acceleration... so... i have decided to drop the exhaust... then the intake... disconnect the shocks... remove the subframe... removed the stabalizer bar... the intake... and wiring... and i will soon remove the last 2 mounts for the engine and tranny to then disconnect the bellhousing and drop the tranny out.... while leaving the engine in the car
its now 1:08 in the morning.... i have jus decided that if anyone or enough people would like me to write up a diy on this... ill make it and take the pictures upon reassembly... or if anyone just has any questions....
its late... ill be back tomorrow
also... im looking at the piping of my exhaust system... does anyone know what the outlets on the head to the header are (dimensions)... that and what are the dimensions of the inlet and outlet of the catalitic converter... im thinking of opening it up with a header and new piping... but i wouldn't be able to validate a larger circumfrance if there will be bottlenecks..... thanx again
Re: complete dismantle
^ no ****... I wouldnt do that... all to find a sound? I woulda just taken it to the honda guys and been like wtf... ha. Write a DIY if you cant, save some questions down the road.
Please do a DIY on pulling out the transmission. My input shaft bearing and my third gear synchro are both shot so the transmission is coming out later this month when I get back from school. Any tips would be helpful gsniper66
okay guys... i will be pulling apart the engine and bell housing today... along with the starter and the last two engine mounts and will soon be cracking open the transmission.... i will start the diy while on the reinstall phase after i find the issue......
the thing is... i can do it.... i would rather crack it open myself and look... which is what honda was going to do anyways... and this way... i can do things write.... i think i may also do a wire tuck on the reinstall.....
Stock exhaust outlets on a D17 head should be right around 33mm ( + or - a mm). I don't have a set of calipers at the house to measure it, but that's what my straight edge says.
the noise is across all gears... only under forward motion under the drive of the engine.... aka... it doesn't do it outta gear.... the noise is relative to the rpm the car is at...
well.... its been about 2 hrs and the tranny had been cracked open... im replacing 4 of the bushings including the pin bushing on the input and output shafts.... its about 125 in parts ordered.... ill grab some pics of the set-up later and actually post em for ya
i have the tranny back on the car.... im bolting the engine mounts back in currently... i'd like to finish the install tonight... and do the diy sometime over the next week
i have pics of everything for the diy... i have like 100 photos and jus need to decide which ones to use... i have many repeats and angles... jus so there would be no questions.... just wanna do it right
the status of the job is that the car is back together and now FIXED... hahahaha.... civic 0.... gsniper 2.... the issue was the main bearing on the input shaft.... the bottom pin bearing on the output shaft... and the 2 top bearings on the output shaft.... the car is nowback together and i will be looking into makeing the diy soon
if u have the right tools... the right knowledge... and the right amount of space and help.... it'd be about a 6 to 8
ill be supplying the knowledge... the rest is up to u
