Tein H-Tech tons of rear sag..WTF?
Old May 31, 2007
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
Ok, a friend had tein h-techs installed on a 05 civic coupe 1month ago and the rear has already sagged to the point that there's only 1 finger gap left...wtf is up with that? i also bought the h-techs but have yet to install mine...i grabbed the h-techs because they were supposed to be a very very minimal 0,8" drop...pisses me off that they end up being about a 2" drop in the rear....if i had known that they were gonna be so crappy, i could have purchased a different brand of springs w/ a stiffer spring rate....
Old May 31, 2007
Kevbotron's Avatar
I like my commute
Re: Tein H-Tech tons of rear sag..WTF?
do you have subs in the back? that could be weighing it down.. It could also be your shocks. Mine were going and I replaced them w/ blues, now my ride height is the same front and rear, when before it was kindof saggy.
Old May 31, 2007
HyeHonda05's Avatar
Official Wish He Knew It All
wow.....not gonna lie...I have never heard or seen H-Techs that sag....and especially that much....I have S-Techs and mine dont sag period....I would take them off and return them and a diff spring like you said....or maybe tell Tein about what happened and take pictures and they will probably either give you a full refund or they will send you new springs.....they have a 1 year warranty that their spings will be free from manufacturer defect.......and they are guaranteed not to sag more than 5mm.
Old May 31, 2007
Kevbotron's Avatar
I like my commute
Hrmmm yeah.. I heard of some knockoff Tiens being sold on E-Bay and what not.. Hopefully you didn't buy those
Old May 31, 2007
Zzyzx's Avatar
Autocross Junky
1st question, did you change out your dampers too?
Old May 31, 2007
mrtrinh's Avatar
mrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of lightmrtrinh is a glorious beacon of light
Yeah you can have blown shocks if you are on oem dampers. I'm not sure about h techs but I have heard of tein s techs sagging, especially with sedans.
Old May 31, 2007
turboslug's Avatar
Super Hoser
my friend's car has a sub in the trunk but it cant be more than 50lbs at most...50lbs should not make it sag so much....
as for the shocks, the car is a fairly new 05 coupe w/ around 30,000kms on the odometer and the shocks do not feel as if they are blown. they do a much better job of damping compared to my 02 worn out stock suspension.
for myself, i have brand new tokico blues that i intend to install w/ the tein h-techs. the springs were purchased from a local authorized tein dealer and the springs appear to be authentic(ie. spring markings are not stickers)
Old Jun 6, 2007
sl33pyriceboi's Avatar
blown rear shocks are possible
Old Jun 6, 2007
kornsined's Avatar
My h-techs have less then a 1 finger gap in the rear. My subs are to blame. When I had my spare back there it was even worse.
I don't think the rears are blown. Haven't noticed anything to suggest they are.
Old Jun 18, 2007
Maple50175's Avatar
Maple50175 is an unknown quantity at this point
Im temping to get these springs, but I hear all thise rear sagging eeek
Old Jun 18, 2007
kornsined's Avatar
checked mine out recently and I wouldn't say there's sag.
Old Aug 20, 2007
turboslug's Avatar
Super Hoser
if you only have 1 fingergap left, then your rear end has dropped to around 1.7-2" lower than stock....the springs are only rated 0.8" drop
Old Aug 20, 2007
turboslug's Avatar
Super Hoser
anyways, i have my h-techs insatalled now...they are coupled w/ new tokico blues...the combo is almost too soft...it's only a tiny bit stiffer than stock or i'm just imaging it is(either that or my stock suspension was just so worn that it was bumpy)...
there's 2 fingergap in the rear(1.25" lower than before) and 3 fingergap in the front....
the rears look nice (even though the rear dropped more than 1.5" lower than stock) but i wish teh front will drop another fingergap....the front is actually sitting at the exact same height before the drop...i guess my original front suspension was already sagged one inch...
Old Aug 20, 2007
Kevbotron's Avatar
I like my commute
whattt too soft? the stiff springs are still there, that "soft" feeling is just the gas shock properly taking the bumps so theres less feel.. the performance spring rates are still all there for good cornering
snap some pics!
Old Aug 20, 2007
redem2's Avatar
redem2 has a spectacular aura aboutredem2 has a spectacular aura about
damn...and i just ordered a set too!
Old Aug 20, 2007
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
I wouldn't worry red. I just put in the pro kits with blues and I smile everytime I drive now instead of stress. the h techs have a similar rating to prokits so I would expect them to be comparable. in my opinion the strut/shock would be more likely to be a factor with a proper install.
Old Aug 21, 2007
turboslug's Avatar
Super Hoser
mine were properly installed...they dont creak or squeak...
Old Aug 21, 2007
kcari's Avatar
go with the S techs... better drop
Old Aug 21, 2007
texascivic2k1's Avatar
THE LONE STAR STATE
texascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of lighttexascivic2k1 is a glorious beacon of light
I enjoyed my H-Techs for a couple of years until the sagging got on my nerves. Then I bought the S-techs and just replaced the front springs and now the car is level (the front might be a little lower). But I haven’t had any problems... it might be something to look in to.
Old Aug 21, 2007
Matteo's Avatar
Matteo will become famous soon enough
s-techs sag in the rear on sedans : /
i just started to notice a little sag now after having them on for about a year and a half and thats after stripping my trunk as well!
Old Aug 21, 2007
Matteo's Avatar
i guess its better to sag in the rear cuz i can just get rs sides and a front lip and leave the rear stock to make it look better
Old Aug 21, 2007
turboslug's Avatar
Super Hoser
i actually want my front end to drop another 0.5-0.75" heh...
the rear is exactly where i want it right now...any lower and it'll be too low...
Old Aug 21, 2007
turboslug's Avatar
Super Hoser
i already have all of that...the front still looks too high...
Old Aug 21, 2007
turboslug's Avatar
Super Hoser
This is the car on a brand new set of h-techs and tokico blues...
I know the photo is dark but that's all i have right now...i can see the car just fine on lcd monitors
Old Aug 21, 2007
THE LONE STAR STATE
I guess this is the best pics to show its stance...
Old Aug 21, 2007
kornsined's Avatar
http://www.imagestation.com/album/pi...?id=2088476463
My photo album with some pics. This is after a year of use with a heavy sub box. NO sag at all. Pics taken without sub box.
Old Aug 21, 2007
turboslug's Avatar
Super Hoser
hmmm..h-techs work well w/ your car..my rear is about the same height as yours but my front is higher...maybe it's because i dont have a k-series to weigh down the front end..hehbtw, your drop is lower than the rated 0,88inch drop specified on their website...looks nice but tein specs are off...oh one more question..does your car scrape at all? it looks low enough to...my front end is still so high that i can plow through speedbumps even w/ an oem lip on the car
Old Aug 23, 2007
kornsined's Avatar
No scrapes at all with anything. If there ever is a chance I go slightly sideways to avoid any scrapes.
Old Aug 23, 2007
redem2's Avatar
man...i'm still waiting on mine! fudgicles! anyhow, some people said the prokit sagged, but when i installed mine on stock shocks they were fine. i guess i'll know some time this week if the h-techs sag or not...
Old Aug 23, 2007
turboslug's Avatar
Super Hoser
so you already have the prokit? why switch to h-techs? aren't h-techs supposed to be similar spring rate and drop?
let me know which you think is better...
