Amp Question
Old Mar 25, 2002
Chuck94527's Avatar
Chuck94527 is an unknown quantity at this point
Amp Question
I'm planning on buying two 12" Cerwin Vega HED Subs in the next week and i have a couple questions about them and the amp that i should get. I'm either going to get the US Acoustics 600x-D Amp 1 or the 800x-D Amp 2. My questions are: 1. Is it worth the extra $90 to get the 800x-D amp? if it was your money what would you do? 2. Would Single or Dual voice coil subs be appropriate for this setup? i don't know the effect of series or parallel wiring so if that effects it please don't ask me what i'm planning on doing. tell me what you would do please. Thank you all in advance for the advice.
Old Mar 25, 2002
neoretromax's Avatar
neoretromax is an unknown quantity at this point
Those are mono amps so you're getting two amps right? personally i'd get the cheaper one since your'e getting two.
Old Mar 25, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
if you want to stay with those brands get the single voice coils and run them in parallel. to make a 2 ohm load. get the 800d and you will be running 300 watts to each sub. right in the middle between rms and peak.
personally i would look into a different setup the amps pretty nice but at least consider different subs
Old Mar 25, 2002
mohawkboom's Avatar
<< if you want to stay with those brands get the single voice coils and run them in parallel. to make a 2 ohm load. get the 800d and you will be running 300 watts to each sub. right in the middle between rms and peak.
Ditto.. but the subs are allright too.. but they're the best of the bargain subs..
Cheers
Mohawk
Old Mar 26, 2002
Chuck94527's Avatar
ok, thanks for the help everyone[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
redcloud
25
Aug 12, 2015 01:23 PM
Civic65
Jul 19, 2015 10:13 AM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
