k20 type R swap in 01 civic ex
Old May 5, 2007
civicdude116's Avatar
civicdude116 is an unknown quantity at this point
Needing some assistance and any help would be greatly appreciated. I have an 03 type R RSX front clip all the way back to the seats. I'm looking at doing a swap in my 01 civic ex. For one I have an automatic, which I have the pedal kit for already. Secondly is the ECU. Do I need to change out my ecu to maybe a civic si ecu? That I do not know. Also, since it is a 6speed, should I also change out the dash kit to a civic si and put the stick shift in the center console? Any help would be awesome. Has anybody done this??? 1 more thing. anybody know where I can order the engine mounts for this?
Old May 5, 2007
D5cIvIc's Avatar
Re: k20 type R swap in 01 civic ex
tsk tsk tsk...searching owns you man.
First of all, as for the ECU, you will use the actually TYPE R ecu or you can use a type s ecu/kpro to make it work. I would use the type S ecu since you can take advantage of the immobilizer function in our cars.
You dash kit, i'm taking as you mean your gauges, can be changed out if you really wanted it. As for me, i'm just changing mine out to the 02 civic manual cluster. You don't need to use the SI CLUSTER, then you would have to go through the trouble of actualyl re-wiring it to work in our cars.
Third, yes you have to switch out the center console part where you automatic shifter sits right now. You would have to order that part around your shifter to adapt to a manual shifter. Its confusing but yes you have to switch out that front part of your center console to the manual one.
Engine mounts can be ordered from http://www.hasport.com/products/mounts.htm
YES TONS OF PPL HAVE DONE THIS. you should really search next time before you post something like this again.
I'm also doing an auto to manual and installing a k20a2 rsx type S motor in my car within the next month.
there is threads on here that states exactly what you need and how to do it. search please
Old May 5, 2007
D5cIvIc's Avatar
here is my thread:
https://www.civicforums.com/forums/4...mber-soon.html
here is the DIY SWAP INFO.
https://www.civicforums.com/forums/7...29-2007-a.html
here is the actual link:
http://www.xproductionz.com/k20swap/k20swap.html
Old May 5, 2007
kasimmmmm's Avatar
since you're asking noob questions, i should warn you not to do it to a daily driver.
It takes a while and money to clean the bugs from the swap. It sucks to have a daily driver go through it but its not too bad if its a project car you have on the side. Trust me i figured it out the hard way.
If i could go back i'd look for and EK shell or even an em2 shell instead of screwing around with my daily driver.
Old May 5, 2007
D5cIvIc's Avatar
^^ i thought you had another car that was your daily driver.
also, is it really that bad now? i know several members who done k swaps and they aren't really have any bugs at all. Just little check engine codes to clear, but nothing really major.
what major problems are you exactly talking about here? Since i'm doing this to my daily driver. I do have a really old car that i have on the side, but this is my main daily driver.
Old May 5, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
nope no one has ever though of doing this, or even done it in there lifetime!
Old May 5, 2007
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
swap.. i didnt know we could swap into our cars... please i need more info. lol
Old May 5, 2007
Dued there was this one time i was sitting in my house, and found a bunch of boxes... So i took them and made them into a fort!
Then i was like wow now i need a dope ride and a hot chick:
But i wanted to make my car faster, it just wasnt fast enough... so i added a few parts:
So i needed some excuses for when i lost a couple races, so i added a gauge:
now life is great! I have a girl *shes under my bed deflated,* i have a sweet ride *oh yea!* and i dont know what im talking about! Got it all!
Old May 5, 2007
i dont know i was bored lol.. needed a good place to post it up lol. Since users dont know what a :
button is for
Old May 5, 2007
LOL got to find a house first lol lease ends in 10 days then im homeless lol
Old May 5, 2007
This is what you would call bored
Old May 5, 2007
Upon further research i have stu,bled across a guy that made a writeup on how to do one of these things called a swap using a motor called a k20.. heres some pics
Old May 5, 2007
yeah i though there was a DIY on this to.. Somthing about adding power adders?
but i could be wrong?
Old May 5, 2007
kasimmmmm's Avatar
i used to have 2 cars but the sedan is now my wife's. So the civic is a daily driver.
its not impossible to have a bug free swap but its pretty difficult to. Unless every part you use is brand new and you've done swaps over a million times to the point that you can do it flawlessly and in your sleep. Trust me no swap is done without having issues here and there, as well as parts wearing out faster than stock parts wear out.
Old May 5, 2007
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
I don't think there is an RSX type R, I think it is still an Integra type R, anyway it is the same car. If it is actually an Integra type R (right had drive and all) front clip that is one hell of a find, where exacly did you get it?? Also if it is a true type R then you have some serious $ in parts that you really don't need to do the swap, the seats and gauge cluster alone would sell for alot $. Also does it have the type R front brakes still intact?? Could you post up pics I would really like to see this thing.
Old May 5, 2007
D5cIvIc's Avatar
ok looking at transformedBG swap...i just noticed that my sub frame is missing the whole front motor mount part. It looks as if someone cut it off. I didn't noticed till now. So anyone here, know if that part is very very essential for the motor to bolt onto the subframe at that particular point?. I would think so, but dam it...i need another subframe now. crap.
Old May 5, 2007
D5cIvIc's Avatar
or else i can get some machine shop to weld something similar there for me to bolt up to the front motor mount
Old May 5, 2007
LOL the bumper is on the car! not on the sub frame.
Old May 5, 2007
D5cIvIc's Avatar
^^wait wat? I don't get it. My subframe is missing that part where i circled up top. Its missing those two black mounting joints where the front motor mounts bolts onto it.
Old May 5, 2007
LOL you probably have it backwards! LOL
Old May 5, 2007
D5cIvIc's Avatar
NOOOO...the motor is not in the car yet
Old May 5, 2007
D5cIvIc's Avatar
the motor and all parts is sitting in my living room. I just noticed that i'm missing tha tpart when i saw tramsformedbg pic.
So i went downstairs to check and sure enough, that part got cut off.
the motor is NOT IN THE CAR THOUGH. I'm not dumb
Old May 5, 2007
D5cIvIc's Avatar
Old May 5, 2007
D5cIvIc's Avatar
yeah well..i'm screwed at the moment. Need another subframe within the next month or so. Since i got an appt. for josh to put in the motor around mid june.
Old May 5, 2007
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I dont think thread starter he is going to post anytime soon in his own thread.
Old May 5, 2007
EMK20a2's Avatar
Originally Posted by Sujak
you have no front motor mount!?
didnt you think something was up when you didnt use one of your hasport mounts?
Man that sucks, that you are missing that mount. I would have someone weld one on for you. BTW I don't think you use a Hasport mount for the front, I think it is the Acura Mount.
Old May 5, 2007
lol.. i have not been using the front mount for 2 years now.. lol
Old May 6, 2007
D5cIvIc's Avatar
whoa whoa whoa...so we don't necessarily NEED to use the front mount??? let me know more about this. Might be able to save some money if i don't need it
Old May 6, 2007
i have never used it period... you can use it if you use a k20 swap.. but if you go with a k24 mount then its useless cause it sits the motor lower about an inch so that front mount wont even line up anymore.
the hasport only comes with 3 mounts.. driver side.. passenger side.. and rear mount
Old May 6, 2007
LOL, that sucks.. i like having a front motor mount, even my solid mount bushing for my k-swap didnt get rid of all my engine movement. Hince the front motor mount being needed for me!
