radio install question...+change odometer lights
Old Apr 9, 2007
mzahidi's Avatar
mzahidi is an unknown quantity at this point
i got a 2000 2dr ex (6th gen)
i wanna know what screws to remove and how to properly remove teh radio in my car....
sorta need a tutorial...
please point me to the right place....
been looking the 6th gen forum...only found directions....
also i just wanna change the background lights from the stock White to blue or red( for the odometer...)
any help is appreciated
sorry if im posting this in the wrong place...
direct this post as neccessary/kick it...?
Old Apr 12, 2007
chopper202's Avatar
chopper202 is an unknown quantity at this point
Re: radio install question...+change odometer lights
Im not sure how to change the background lights but I can give you a hand with the radio I only changed my radio 2 days ago.... You have to remove the whole lower part of the dash the screws inside the glovebox area and all the way across to under the steering wheel...Some of the screws are hard to find but there is 10 in total...once you have got the lower part of the dash off dissconnect the cigeratte lighter wires just by pulling the plug apart and remove it from the car...Now if this is a stock radio when u look up and under the dash you will be able to see the rear of the heater and fan control and directley above that there is the radio..there are only 2 screws holding the radio in and they are black and are removed using a philips head screwdriver.. they should come right out and be carefull not to drop them because they are easly lost in there..now with a gentle pull at the front of the stereo it should slide right out, pull it out just far enough to expose the wires and remove the plug with the speaker wires and the antenna and now ur stereo is out.. to put the lower dash back in just remember where all the screws came from and just do the opposite to taking it off...if you got anyproblems with this just let me know and ill clear it up
Old May 13, 2007
mzahidi's Avatar
thanx dude
i did that myself...but exactly what u said...
its actually very simple....
now i wanna change the backlights to the dash display "speedoment, techmeter...etc"
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
trellex
May 24, 2015 04:39 PM
paddystrang
May 18, 2015 09:56 PM
WLakers
May 4, 2015 06:23 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
