full hid retrofit
Old Apr 1, 2007
full hid retrofit
Valeo H7 projectors $110 shipped
Valeo ballasts D2S $120 shipped
Osram D2S bulbs $65 shipped
$280 shipped for everything
all you need to have a complete retro are the H7 to D2S adapter plates which sell for $10-20 on ebay or hidplanet.com
These projectors, although halogen, are well known for their excellent output with hid bulbs using the adapter plates.
Old Apr 3, 2007
Ricanwizard's Avatar
Ricanwizard is an unknown quantity at this point
Re: full hid retrofit
you have pics?
Old Apr 4, 2007
Old Apr 5, 2007
how easy is it to install
Old Apr 5, 2007
could i install these on stock headlights ? if so wha do i need to do it?
Old Apr 5, 2007
i think you might need to research this more. the install is quite difficult. you have to cut a hole and mount the projectors into your headlight. then the bulbs go in the projector and ballasts power the bulbs with an upgrade wire harness.
now you could also use just the bulbs and ballasts and put them in your stock headlight using these shields if you have 01-03 civic. they fit H4 bulb hole and the D2S bulb goes behind it. then you just need to wire the ballasts to power them and you wouldnt need the projectors.
http://www.casperselectronics.com/Me...Category_Code=
Old Apr 16, 2007
0H3ebpEM2's Avatar
0H3ebpEM2 will become famous soon enough0H3ebpEM2 will become famous soon enough
once again im interested in your setup. how much would it cost me to run that setup in stock headlights minus the h4 adaptor shield
Old Apr 16, 2007
okay heres the deal, i am currently working on sealing the ballasts and cleaning them up. i also have a pair of d2s to H4 adapters, but the bulbs have some silicone on them and dont fit in perfect. but i can sell you the ballasts and the adapters, then you just need a harness from suvlights.com to hook it up properly and some new d2s bulbs. hidplanet.com always has used bulbs for pretty cheap so you could check there.
i can do $150 shipped for both d2s ballasts and both adapters. if you want to try and clean up the silicone on the bulbs i have ill throw those in for $50 more. they are fairly new bulb but you just need to scrape off the silicone residue on the base.
Old Apr 16, 2007
0H3ebpEM2's Avatar
gearbox look at this retro for me and tell me what you think of it? im asking if the guy will take 350 for it
https://www.civicforums.com/forums/1...-ballasts.html
Old Apr 17, 2007
ya thats actually a good deal and some nice hardware and it even looks good unlike alot of others in oem housing. the only problem with those is the overlapping beam of one of em, its not a huge deal but they arent perfect. and i dont think its something related with aiming, its just the way they were installed.
17
Jul 23, 2015 11:48 PM
