1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Engine smoking
Old Mar 27, 2007
carthik's Avatar
carthik is an unknown quantity at this point
Engine smoking
My engine on a 93 DX is smoking alot. what could the problems be? and what would it involve replacing? Lastly, how much would this cost me (in parts),
Thanks
Carthik
Old Mar 27, 2007
PowerWheels86's Avatar
PowerWheels86 is an unknown quantity at this point
Re: Engine smoking
what colour of smoke? white smoke? your burning oil... if i were you get a job that pays well or rob a bank or something because that baby is better off with an engine swap... by the way... you don't have to post twice to change a few words in your posts... there's an edit button for that
Old Mar 29, 2007
Lomaxx's Avatar
Lomaxx is an unknown quantity at this point
Re: Engine smoking
is the smoke coming from under the hood or from the exhaust if oil was spilled on block this could explain smoke from under hood
Old Mar 30, 2007
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Re: Engine smoking
could just be overheating if the smoke is white from under the hood. check to see for any spills or fluids on the block or any other parts under the hood. If it is smoking from the exhaust that could mean something as simple as you cat. going out or you could have serious problems in the motor.
Old Apr 6, 2007
zonk's Avatar
zonk is an unknown quantity at this point
Re: Engine smoking
color of smoke
white=water leaking into cylinder(if this happens your oil will probably look like chocolate milk, and if thats the case you wither got a bad head gasket or a crack int he block)
blue/gray= oil burnin(usually means rings are shot or possibly something worse)
black= running rich fuel mixture(need to adjust injectors, fuel pump possibly running wrong, or bad main fuel relay located under the dash by fuse box)
thana
Jun 15, 2020 07:05 PM
crowtoo
May 11, 2015 06:50 PM
WhosYoDadday85
Dec 30, 2001 06:31 PM
viper775
Dec 10, 2001 12:16 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
