Need help with all types of maintenance
Old Mar 24, 2007
gameboi499's Avatar
gameboi499 is an unknown quantity at this point
I'm not in school this semester so I thought this would be a great time for me to do all the necessary maintenance work on my car:
-oil filter
-air filter (both cabin and intake)
-transmission fluid
-coolant
-spark plug
-brakes
I usually only do oil filter myself, but I need help with pretty much everything else. I drive an 01 ex coupe. Sad thing is I bought this car used and so I don't have the manual. Can someone take a picture of where everything are? For starter, where do I drain out the coolant and the tranny fluid? I guess if I go under the car I can figure out where these two are. But just incase they aren't obvious, can someone post some pix? Also how do I gain access to the cabin and intake filter? Is there anything that I should be aware of before I start?
Old Mar 24, 2007
Lord ET's Avatar
Lord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of light
Re: Need help with all types of maintenance
for the cabin air filter, you can remove the two clips in the glove box when you open it....the glove box will swing down and you will see a plastic box and you can figure it out from there. To remove the tabs don't open the glove box all the way, but enough to get your hands in, and pull the bottom portion of the tabs toward the middle of the glove box.
Old Mar 25, 2007
gameboi499's Avatar
Ok how often do you guys recommend changing the transmission fluid if I drive an auto
Old Mar 25, 2007
speedricerx's Avatar
speedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of lightspeedricerx is a glorious beacon of light
i recommend you use the search button.
edit: There IS a whole section dedicated to DIYs.
Old Mar 25, 2007
RHCP0801's Avatar
you need a 3/8th inch ratchet to remove the drain bolt(has a square head in the bolt for just the ratchet to be used, no socket) for the tranny fluid, its on the passenger side next to the frame...tight fit and let that drain than put 3 quarts of honda ATF in through the dipstick.
the filter under the hood you just need an 8mm socket i believe and remove all the bolts, around 8 or so than just pop in the new one
coolant is best to use a machine, they flush out the old coolant and put it new coolant while it does that
spark plugs you just need the spark plug socket to take out the old ones and put in new ones
brakes depends, can be just pads or new rotors or get the rotors cut if your pedal shakes when you step on the pedal...cause they are warped. Than there are the brake shoes in the rear too
how many miles are on your car?
Old Mar 27, 2007
gameboi499's Avatar
Thanks for the reply. I have 60k miles on my car
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
anubis62
Sep 27, 2015 12:56 AM
